- 30 Aug 2018
Hah! I wish I could speak German!Ive just read this in der8auer voice![]()
Do you still have that?
Kein Kumpel, ich habe es schon vor Jahren verkauft.![]()
ty.Running my 9900k on a z390 master board, at stock all cores sit at 4.7 and under prime will pull 1.39v, if i ramp up to 5ghz across all cores im pulling 1.480v. Seems a tad high to me, this is with all voltage settings on auto on the board. Where should i start to try pulling those voltages down a bit? I'm slightly overwhelmed by the sub menus on the gigabyte z390 board..seems overcomplicated compared to my previous asus boards.
Have a look on YouTube, quite a few Gigabyte Z390 Master overclocking guides on there, but using auto will always overvolt, for 5.0ghz I would start at 1.25v vcore, and run Cinebench, and work from there. 1.390v is way over the top for 4.7ghz.
This isn't usually the case with the top cpu on an older intel platform.Happy with my i5 8600k atm, would the price drop in a couple years? Then could pop one in my current board.
Brand new the old cpus dont get reduced to clear and the second hand market prices are kept high because it's the best anyone wanting to stay on the same mobo can buy, so demand is high.
Typically the next best cpus, so 9700k/9600k, are the most affordable options second hand.
Then again, if there are more processors available for the socket in the future and the 9900k is no longer the top one, then yes, expect prices to fall.
So with that said, expect 8700k, 8086k possibly and 9700k to be the most reasonable upgrades second hand in a couple of years. 9900k is likely to still command a premium.
9900k is likely to still command a premium in a couple years. Considering what`s in the pipe or shall we say changes coming that would surprise me. Buyers of 9900k today are setting their self up for a big £££ hit when they come to sell S/H - upgrade.
I'd gladly get a 9700/9900K but I know that their will be pretty much zero difference between them and my 8600k at the same clocks (5.1) so it's just not worth it.
ty.
Shame, I would be interested to see the 9900k with phase change. How are you getting on with yours as is? Have you settled on a 24/7 OC yet or are you still tinkering?
Depending on application.
Been playing about with my 9900k/z390 master setup to try to reduce the vcore a bit. Chip sits comfortably at 4.7 out of the box and the only change i have made is to enable 3200mhz on the ram. At the moment vcore is on auto and i feel it is adding too much voltgage. At 1.275 my system can pass every stress test and performs fantastically while gaming, zero issues providing i apply the voltage settings and restart system from bios, But on a cold start it will blue screen at windows login. I have went as high as 1.390 and still it will bsod on login. Where else should i be looking to make adjustments?
Set your vcore manually. Don’t let gigabyte especially do it for you. They are not good at it. LLC=turbo if you oc to 5.
I have been setting it manually over the weekend and have went as far as 1.390v but still bsod on windows login. At the moment i want to create a profile with a low vcore for stock 4.7 then start pushing up to 5ghz
Something isn’t right. That’s too high of vcore for @ 4.7.
