but not anymore.
not much wobble of the monitor on my table.@Daniel - LG any news on next shipment of monitors?
should be some this month, just waiting to find out
Yes the same in my unit , 5mm difference . I working in aerospace industry so that bother me a little bitWell monitor arrived yesterday and while there was a massive gash in the side of the box the contents seem ok. Screen looks great, no dead pixels that I can see, and back light bleed no worse than on my previous AW3418DW.
Does anyone else have a similar issue to below? When mounted in the stand the monitor is (via super scientific lego measurements) approx. 5mm higher on one side to the other. My desk is level so not sure what causes it. However there does seem to be quite a lot of movement where the stand clips in to the VESA mount of the screen.
@Daniel - LG / @anyone else with 34GK950, thoughts appreciated..
,Yes the same in my unit , 5mm difference . I working in aerospace industry so that bother me a little bit,
I previously had two AW3418DW which I sent back as both had the same issue (though one did have a dodgy screen as well). The Alienware has a very similar mounting arrangement where it attaches to the stand.Meybe Vesa desk mount solve that problem ?once you notice its off it is quite noticeableI previously had two AW3418DW which I sent back as both had the same issue (though one did have a dodgy screen as well). The Alienware has a very similar mounting arrangement where it attaches to the stand.
Thought it would be easier to visualise the difference![]()
