That's a lotta lotta water.@Werewolf
I've just had a sprinkler system installed in a 50m x 30m 'shed'. To extinguish a fire within the pumps I've specified have to provide at least 7000l a minute.
Do you have a tank or is it from the mains?
Ive not heard that detail, unfortunately there is a lot of misinformation and misunderstanding that can lead people to believe in anything. Many people refused to be believe Elvis was dead, it was highly improbable but also he took drugs and its reasonable that he passed away in the way recorded but I dont blame people for thinking otherwise.In atleast two of the planes a pilot managed to change the communications over to broadcast before being removed from the controls.
The twin towers are right next to a large water source like that. The main thing misunderstood on the towers collapse is about the removal of asbestos from the steel girder structure, I've read both that fire protection was removed in more recent years but also that asbestos was removed during construction. Either way the building was not able to resist fire, it should not have been used while vulnerable and I would like to hear engineers discuss that more but I rarely see any scientific discussion in that direction.Mains can't supply enough. Ordinarily you'd have a tank however we have a river.
IIRC it was quite well known the towers were not up to scratch for thermal protection around the structure (I don't think they used asbestos but something else they sprayed on as they were built after asbestos was a known risk), a few years back I found a study that some architecture student was doing using the towers as examples of how slapdash the application of this particular fireproofing method had been and how it could affect the structure compared to what it was intended to take, from memory he chose them because they were built at the same time, generally the same construction but one was undergoing replacement/upgrading of the heat protection.I think this kind of aspect is what is fuelling a lot of the conspiracy angles like Grenfell with things not upto code, shortcuts taken, etc. but being covered up.
‘There are so many questions that the Americans and the British Establishment refuse to answer,’ he says. ‘I believe that my brother and thousands of others were murdered on 9/11 and there has been a cover-up. We, as a family, are still overcoming this tragedy, but we will never stop seeking the truth.’
...attack by foreign sheep herders.
Hey Mulder - look closer.This thread moves more quickly than I check here, but I'm giving up on responding to Dowie who just seems to continually ask questions and not actually respond to any points.
Reading through the last couple of pages, I'd point out:
Conspiracy theory basically means "not the official story". So not only are many conspiracies true in history (i.e. the official line has turned out to be bull) more than half of Americans (according to one survey) believe in them today. That's a lot of nutcases.
Families - the "people died, have respect" brigade must be forgetting the families of victims who believe in an alternative version of the story. Of which there are many. For example Matt Taylor, whose brother Geoff died on the day. Matt has previously said:
WT7 Freefall - those saying WT7 didn't fall at freefall are wrong. NIST openly now admits (they didn't originally) that the building, for a period, fell in freefall. Look it up in the NIST filings. That means there was zero force pushing up at the building for that period. That's impossible in any natural scenario, and one reason why thousands of engineers are calling for the truth.
I'm aware you believe the official story is wrong, what I'm interested in (and I've asked a few times now) is why? What about it is wrong? What do you believe happened?My point is basically:
- The official story is wrong, on many counts, and history will eventually see those that question it (omg you're a nut case!) proved right, as has been the case for dozens of other conspiracies that turned out to be true (see my previous post for a selection)
Anyone studying it in detail, and without bias, will come to this conclusion (as have millions of people, including engineers, academics, families of the 9/11 victims, firefighters on the ground during the day, architects etc)
Well that is clearly false for a start as plenty of investigators have studied it in detail and not arrived at conspiracy theories. If you want to claim that some people have some alternative ideas or conspiracy theories then sure, I'm aware of that.
One of the most relatable points is WT7, which provably could not have collapsed as it did according to the official story. NIST admits the building fell at freefall for a period of time, which as many independent experts have shown, cannot tie in with fire causing the collapse. Freefall is impossible for a naturally collapsing building.
But you won't look into it, because you know you're right, and that anyone questioning the official story must be nuts. Even though, that mindset in itself is nuts, and history proves so.
But I won't look into it??? I've been repeatedly asking you to actually lay out what it is you think is wrong? That is the very opposite of ignoring it/not looking into it- I'm actively trying to find out more about your claim, asking you to explain your position....
Can you clarify what you're saying here - what do you mean by WTC7 "provably could not have collapsed as it did according to the official story"?
WTC7 did collapse, it is caught on video collapsing? What specifically is wrong about it collapsing? And what is the alternative explanation for why it collapsed?
The NIST report is publically available. It doesn't say what the conspiracy believers claim it says. No surprises there. There were 2 seconds during the collapse when part of the building was in free fall. That's it. What do people think would happen when part of the support in a tall building fails? Bits above it will fall under mavity for short periods of time until they hit something else. That's mavity, not invisible explosives laid by invisible people or alien destructo-rays.
If you scour a beach and find one tiny gold nugget and millions of stone pebbles, that doesn't prove that the beach is made of gold.
Anyone got any more news, they've been banned from steem, twitter and the darknet forums kickass have been seized by the FBI on the requesy from a court in NY. They must have some interesting material. [..]
I guess that means the 'donations' have dried up already. Not surprised. Reading through that lot is probably about as entertaining as going through random people's car insurance policy documents, with only the word of a hacking group that admits it's financially motivated to go on that there'll be anything remotely interesting in there in $2 million dollars time.To create a bit more buzz, we've decided to continue forward and release the decryption key for Layer 2.
https://www.rt.com/usa/448416-hackers-leak-more-911-docs/When not leaking government and corporate documents, the group makes a living selling credit card information and medical records.
The group may have a hard time paying its members if the latest ransom demands are not met, however. Cyberscoop reported on Tuesday that the group was posting recruitment ads on dark web forums in November, looking to hire four skilled cybercriminals.
New employees were reportedly promised 50,000 pounds ($63,500) monthly, bumped up to 70,000 pounds ($89,000) after two years’ service.
I urge anyone who believes this to read the NIST report. It does not say what Mulder et alia are claiming it says. The report is publically available.
The fact their outright criminals who are easily identified on twitter has nothing to do with them getting banned from it I assume?Anyone got any more news, they've been banned from steem, twitter and the darknet forums kickass have been seized by the FBI on the requesy from a court in NY. They must have some interesting material.
Is it not possible to capture someone even on the darknet, I thought you could monitor nodes on the network or something, surely the NSA have some tricks up their sleeves?
I mean I can't imagine what could possibly cause a legitimate (or likes to pretend to be one) like Twitter ban accounts linked to massive personal data breaches such as theft of medical records and credit card numbers.
I can't guess why a company might not want to give a platform to such fine, upstanding seekers of truth as that.
I mean who hasn't broken into highly personal information and sold it to the highest bidder, or dealt in credit card fraud, it was only last week I was saying to my buddy d4t4th31f69 on dorkwob about how it was a shame that it was getting harder to sell the information without those annoying legal authorities trying to barge in a spoil the fun and deny us a chance to make some dough.
