Hacker group releases '9/11 Papers', says future leaks will 'burn down' US deep state
13 Jul 2004
Stanley Hotel, Colorado
In atleast two of the planes a pilot managed to change the communications over to broadcast before being removed from the controls.
Ive not heard that detail, unfortunately there is a lot of misinformation and misunderstanding that can lead people to believe in anything. Many people refused to be believe Elvis was dead, it was highly improbable but also he took drugs and its reasonable that he passed away in the way recorded but I dont blame people for thinking otherwise.
The moon landings also are highly improbable from a laymans perspective but NASA was mostly about the cold war and rocket technology development more then scientific exploration, the moon has little reason to go there. The space race is parallel to nuclear power stations imo, its a precursor to world war 3 that we hope will never happen.
I dont blame people for doubting the moon landings, it might be improbable if the military aspect were not there as obvious motivation. Theres no big jump in logic required to recognise the correlation in progress between those two branches of government
I think the 9/11 failure was incidental to the crashes and that is perhaps why we get more conspiracy theories. What is being overlooked and needs to be underlined to prevent repetition is mistakes not deliberate sabotage
Mains can't supply enough. Ordinarily you'd have a tank however we have a river.
The twin towers are right next to a large water source like that. The main thing misunderstood on the towers collapse is about the removal of asbestos from the steel girder structure, I've read both that fire protection was removed in more recent years but also that asbestos was removed during construction. Either way the building was not able to resist fire, it should not have been used while vulnerable and I would like to hear engineers discuss that more but I rarely see any scientific discussion in that direction.
Asbestos is a fire protection (in recent years its not used due to cancer fears) required to stop or slow the weakening of the steel under heat, hence the famous meme about jet fuel not being sufficient to cause total failure. It doesnt have to cause total failure, just partial weakening was enough and the building was not fit for use is not a conclusion I've ever heard but seems it is key to why it failed in the way it did.
The terrorists probably didnt even calculate this part, an immediate effect from collision is my estimate of their plan but I'm not sure whether they had researched or realised events would gain the most momentum after the crash. The goat herder line is ignorant, Afghanistan and many other countries, their populations are far older then how they are currently caught in civil wars. They have more then enough intelligent people in the middle east to envision, coordinate a plane hijack plan and the basic violent plot is not far past other instances but the final part with the missing fire resistance even now is understated which is unfortunate.
Theres nothing wrong with discussing the failure but always human nature and mistakes are possible even by otherwise intelligent people, that will always be what must be disproved first
https://www.asbestos.com/world-trade-center/
https://en.wikipedia.org/wiki/Structural_integrity_and_failure#World_Trade_Center_Towers_1,_2,_and_7
tl;dr Im not an engineer but I'd like if a few of them discussed these details ad infinitum pretty much, the whole subject is continually relevant to any city population imo
Man of Honour
13 Oct 2006
I think this kind of aspect is what is fuelling a lot of the conspiracy angles like Grenfell with things not upto code, shortcuts taken, etc. but being covered up.
Commissario
17 Oct 2002
Panting like a fiend
IIRC it was quite well known the towers were not up to scratch for thermal protection around the structure (I don't think they used asbestos but something else they sprayed on as they were built after asbestos was a known risk), a few years back I found a study that some architecture student was doing using the towers as examples of how slapdash the application of this particular fireproofing method had been and how it could affect the structure compared to what it was intended to take, from memory he chose them because they were built at the same time, generally the same construction but one was undergoing replacement/upgrading of the heat protection.
I wish I'd saved a link to it, as by the time the CT's started flooding the internet with nonsense it basically became impossible to find useful information from lesser known sources unless you could remember a lot of specific detail (such as the name or a keyword that hadn't been hijacked by the CT's and the scammers that feed them nonsense), but from memory his work (which involved masses of photos) showed.
Fireproofing was inconsistently applied - it should have been uniform throughout as any place it went under the minimum was a weak point that affected that entire section,
Fireproofing hadn't been applied in some areas, not just hard to reach spots but some easy to do ones.
Fireproofing had broken away (a sign it had been badly applied/mixed or damaged) and not replaced.
Basically it wasn't up to scratch and there were signs only areas that had actually been inspected independently had been done consistently well, but it was in the process of being fixed, hence his timing on doing the study as it was basically then or never.
10 Oct 2004
Bucks
This thread moves more quickly than I check here, but I'm giving up on responding to Dowie who just seems to continually ask questions and not actually respond to any points.
Reading through the last couple of pages, I'd point out:
Conspiracy theory basically means "not the official story". So not only are many conspiracies true in history (i.e. the official line has turned out to be bull) more than half of Americans (according to one survey) believe in them today. That's a lot of nutcases.
Families - the "people died, have respect" brigade must be forgetting the families of victims who believe in an alternative version of the story. Of which there are many. For example Matt Taylor, whose brother Geoff died on the day. Matt has previously said:
‘There are so many questions that the Americans and the British Establishment refuse to answer,’ he says. ‘I believe that my brother and thousands of others were murdered on 9/11 and there has been a cover-up. We, as a family, are still overcoming this tragedy, but we will never stop seeking the truth.’
WT7 Freefall - those saying WT7 didn't fall at freefall are wrong. NIST openly now admits (they didn't originally) that the building, for a period, fell in freefall. Look it up in the NIST filings. That means there was zero force pushing up at the building for that period. That's impossible in any natural scenario, and one reason why thousands of engineers are calling for the truth.
Caporegime
29 Aug 2007
Auckland
Hey Mulder - look closer.
Caporegime
29 Jan 2008
Don't lie, I responded to all your points in your previous post - I literally quoted each bullet point (see below), why not just provide some clarification on your position - why is it so hard for you to just engage in discussion and provide a coherent explanation. You seem to just make vague points about the building not collapsing as expected and then when questioned you deflect... I've wasted some time re-quoting the below as you've made a false assertion there. I'm simply asking you for an explanation and have done so a couple of times now yet you're seemingly unable to provide one.
Perhaps reflect a bit on why this is? If you had a solid argument then it it would be rather easy to just provide straight up responses/explanations to anyone who had straight up questions about it... It isn't like I'm asking you loaded questions here or trying to trick you etc.. I'm literally drilling down into what you're actually putting forwards here and asking "why?" or asking for clarity on what you mean by certain statements you've made. If you're unable to do that then then problem is with you and some rather disjointed thinking on your part.
My point is basically:
  • The official story is wrong, on many counts, and history will eventually see those that question it (omg you're a nut case!) proved right, as has been the case for dozens of other conspiracies that turned out to be true (see my previous post for a selection)
I'm aware you believe the official story is wrong, what I'm interested in (and I've asked a few times now) is why? What about it is wrong? What do you believe happened?
Anyone studying it in detail, and without bias, will come to this conclusion (as have millions of people, including engineers, academics, families of the 9/11 victims, firefighters on the ground during the day, architects etc)
Well that is clearly false for a start as plenty of investigators have studied it in detail and not arrived at conspiracy theories. If you want to claim that some people have some alternative ideas or conspiracy theories then sure, I'm aware of that.
One of the most relatable points is WT7, which provably could not have collapsed as it did according to the official story. NIST admits the building fell at freefall for a period of time, which as many independent experts have shown, cannot tie in with fire causing the collapse. Freefall is impossible for a naturally collapsing building.
But you won't look into it, because you know you're right, and that anyone questioning the official story must be nuts. Even though, that mindset in itself is nuts, and history proves so.
But I won't look into it??? I've been repeatedly asking you to actually lay out what it is you think is wrong? That is the very opposite of ignoring it/not looking into it- I'm actively trying to find out more about your claim, asking you to explain your position....
Can you clarify what you're saying here - what do you mean by WTC7 "provably could not have collapsed as it did according to the official story"?
WTC7 did collapse, it is caught on video collapsing? What specifically is wrong about it collapsing? And what is the alternative explanation for why it collapsed?
Man of Honour
5 Dec 2003
Just to the left of my PC
I urge anyone who believes this to read the NIST report. It does not say what Mulder et alia are claiming it says. The report is publically available.
I'm reminded of the moon landing conspiracy believers who claim van Allen's report states that the eponymous belts would be fatal to humans and cite that as proof no human has ever been higher than the lower end of low earth orbit. A few words taken out of context and offered as proof of something completely different. van Allen's report does state that the eponymous belts would be fatal to humans without protection and goes on to say that's why appropriate measures had to be taken. Which they were.
Conspiracy believers don't give a rat's arse for the truth. They're calling for everyone to agree with everything they say, regardless of any and all evidence. It's an act of faith, not an investigation.
EDIT: I'll just quote myself rather than typing it out again:
The NIST report is publically available. It doesn't say what the conspiracy believers claim it says. No surprises there. There were 2 seconds during the collapse when part of the building was in free fall. That's it. What do people think would happen when part of the support in a tall building fails? Bits above it will fall under gravity for short periods of time until they hit something else. That's gravity, not invisible explosives laid by invisible people or alien destructo-rays.
If you scour a beach and find one tiny gold nugget and millions of stone pebbles, that doesn't prove that the beach is made of gold.
17 Jun 2012
Anyone got any more news, they've been banned from steem, twitter and the darknet forums kickass have been seized by the FBI on the requesy from a court in NY. They must have some interesting material.
Is it not possible to capture someone even on the darknet, I thought you could monitor nodes on the network or something, surely the NSA have some tricks up their sleeves?
15 Oct 2018
To create a bit more buzz, we've decided to continue forward and release the decryption key for Layer 2.
I guess that means the 'donations' have dried up already. Not surprised. Reading through that lot is probably about as entertaining as going through random people's car insurance policy documents, with only the word of a hacking group that admits it's financially motivated to go on that there'll be anything remotely interesting in there in $2 million dollars time.
When not leaking government and corporate documents, the group makes a living selling credit card information and medical records.
The group may have a hard time paying its members if the latest ransom demands are not met, however. Cyberscoop reported on Tuesday that the group was posting recruitment ads on dark web forums in November, looking to hire four skilled cybercriminals.
New employees were reportedly promised 50,000 pounds ($63,500) monthly, bumped up to 70,000 pounds ($89,000) after two years’ service.
https://www.rt.com/usa/448416-hackers-leak-more-911-docs/
:rolleyes:
17 Jul 2007
Solihull-Florida
You do know that the first NIST report that was published was wrong?
Yes they admitted they got it wrong(free fall). A school teacher had to put them right!
In the final report they included free fall on WT7. But the math of the free fall that NIST has published does not add up.
The teacher even shows you have to calculate free fall.
Anti-CTs are just as bad a CTs. In fact even worse.
Caporegime
29 Jan 2008
I wouldn't necessarily draw that conclusion, they've got some stolen documents that they seem to have made a big fuss about - there doesn't seem to be much that is particularly interesting.
Commissario
17 Oct 2002
The fact their outright criminals who are easily identified on twitter has nothing to do with them getting banned from it I assume?
I mean I can't imagine what could possibly cause a legitimate (or likes to pretend to be one) like Twitter ban accounts linked to massive personal data breaches such as theft of medical records and credit card numbers.
I can't guess why a company might not want to give a platform to such fine, upstanding seekers of truth as that.
I mean who hasn't broken into highly personal information and sold it to the highest bidder, or dealt in credit card fraud, it was only last week I was saying to my buddy d4t4th31f69 on dorkwob about how it was a shame that it was getting harder to sell the information without those annoying legal authorities trying to barge in a spoil the fun and deny us a chance to make some dough.
17 Jun 2012
Fair point. Apparently the kickass forums being seized was fake also.
