That is a lot of injuries![]()
I was speaking generally
I've got a bad knee right now and my left shoulder is 80% improved.
I was missing range at the bottom because if I went any lower they wouldn't come upI could also feel my shoulder struggling to stabilise the weight properly.
Fair enough. I always end up in limbo with DB bench.
Once I get to 3x8 on whatever weight I'm using my form is good but when I move up (they are only 2kg increments) my form is more like the above (just past 90 degrees at my elbows but still a little range left), then by the time I get to 3x8 it's good again. I'm not really sure there's much of a way around it for me.
Ours only goes to 40kg, but I'm not even using the 30s yet ss meh![]()
Personally I've tried heavier DBs in some other gyms and they were a bit too big/unwieldy. I think I used the 60s.
For me the 50s will always be enough as a secondary movement, the bench press is where I go to shift the larger weight.
OHP is always a slow gainer. It is my weakest by far. I stall so often - then I have weeks when I have no trouble at all. Very unpredictable I find.
The DOMS are real
