**** The Official OnePlus 6 Thread ****
19 Jan 2006
All over the Oneplus7 - My OP5 has done sterling work for 18 months now and will do fine till the 7 comes out but unless they screw something up bad - certain purchase for me.
Been so impressed with the OP5 for the price of £450 and £11 sim!
1 Nov 2007
England
Yeah. The only thing I'll do this time around is order it direct from OnePlus rather than getting it from o2.
20 Aug 2006
Probably going to buy a Oneplus but in quandry which to get
6 looks good at 439 but if want more than 64gb it'll be nearer 490
6T looks good pity no led notification sea better value than 6 if want more than 64gn storage
Or 5T which is.only.349 and is 128/8
Mmm decisions decisions
2 Oct 2006
@£499 for the 6T with 6GB of Ram and 128gb as standard, it’s a steel. It’s truly a fantastic phone. Speedy updates, quality premium feel and good screen.
In-screen ginger print reader for me has been flawless.
18 Oct 2002
Brighton
I didn't have any problems with o2 either but since I'm now on another network it seems like a good idea to get it from the source rather than a network I don't use.
It was nice to have a physical shop/people to go and pester when Oneplus' support let me down with my 3T, I bought the phone outright from then so they had to support it regardless of whether I as using O2 network or not.
14 Jul 2009
You can get a 128gb 6 for under £400 on Amazon France
20 Aug 2006
thanks mmmmm - I think siding towards a 6T - 6/128 seems superb value
has anyone found reception problems ? I've found quite a difference between my Note 3 and my Iphone SE - the Note is now no longer working but my Iphone SE does really well for a signal where the Note was just a month or so back really struggling
6 Jan 2011
London
Anyone successfully using the Tile Bluetooth finder things? An update to my OnePlus 6 made it incompatible and despite several updates since, the tiles still won't connect
12 Jun 2006
Essex
I've absolutely no reception issues with my 6T, having work & personal sims in there helps though!
Great phone, no regrets coming from a 5T (apart from the notification led)
7 May 2012
Bournemouth
Not fussed. Been with T-Mobile/Orange/EE for nearly 10 years and quite happy with them :)
By the way I double checked and it's the 6GB version I have. Can't make that much difference anyway.
Although today I noticed that I can unlock my 6T with any finger?? It's set to my right thumb print :confused:
8 Jun 2007
Face unlock kicking in or trusted places ?
20 Dec 2004
What's happened to the OP5 to make you get a new phone, if you don't mind me asking?
19 Jan 2006
Nothing - I still have the OP5 - the OP7 isn't out yet. OP5 will do me till the OP7 comes out as that will be around 2 years from buying the OP5. I'm just saying that if the rumours and initial looks of the OP7 are as they say they are then I'll probably buy it
If that makes sense.
1 Nov 2007
England
If the OP7 has stereo speakers that would be another good reason to upgrade. I honestly don't care if they don't have a headphone jack. I'll just keep an adaptor connected to my headphones all of the time.
