Hi DJMK4 - how did you get on with this?
Just as I was starting to think I had a good phone that I was going to keep for a long time, it would appear that the latest in a long line of glitches since I got this phone is that it will now decide whether it wants to charge or not, and if it does, it will decide how fast it will charge.
Last week there was one or two instances where I plugged in overnight to find it still sitting at around the same percentage in the morning.
Yesterday I really hammered it through the day so when I got home I decided to top it up as I anticipated using it again in the evening to play some music. After 45 minutes of being on charge, it went from 25-28%. Pathetic. I plugged it back in again and left it for half an hour and it went up to 42% (after it had dropped once more to 26%).
So it was again 26% when I plugged it in at bed time and left it charging overnight, verifying that it was plugged in correctly and charging, and yet in the morning it had only managed to reach 90% after 8 hours of charging.
So essentially, I am left with a phone at (a) I don't know if it will charge at all when I plug it in and leave it, (b) if it does charge, I don't know how far it will charge and (c) I cannot rely on fast charging it for a quick boost because a sizeable percentage of the time it refuses to fast charge (or charge at all).
I have already cleaned the charging port and fairly recently did a factory reset so I'm running out of options of things I can do myself.
So... I bought the thing through mobiles.co.uk - so I have no idea what my warranty rights are, the phone is about 14 months old... although frankly the idea of a free iPhone XR through work is getting ever more tempting![]()
Charging wise. I think it's ok. Rapid charging is hit and miss. And it does sometimes charge slow.
I have an issue with earphones using the USB-c port though. If I move the phone slightly it activates a feature on my phone interuppting the audio. Something which I had on a previous phone..
The USB-C charge ports are really flimsey . Using it for audio is a pain.. may try get some Bluetooth earphones but Im not a fan of Bluetooth due to quality loss disconnections and also battery drain
