The Pi update breaks Call Recorder. According to Killer Mobile they have deliberately disabled call recording. I wish I'd known that before upgrading my S9, I wouldn't have done the upgrade.
I don't get why they would do this. It's a real pain, I used Call Recorder all the time.
The S7/S7e are not even 3 years old yet as they were released in March 2016Why would they continue with developing major OS upgrades on a phone over 3 years old when no other Android OEM does?
Many S7 & S7e edges are not even 2 years old yet as the S8 didn't even get released till 28th April 2017I don't know why people are complaining. You knew what the deal was. If you want is.updstes.on.a e year old phone, then you should have bought the pixel instead.
SO you think mobile phones that are less then 2 years old are old phones and should not get these major updates![]()
Nearly melted my S7 Edge yesterday. Normally extremely careful where I put my phone down, but I put it down without looking properly, it was on my hob. Smelt burning behind me and reacted quickly. Fortunately it was in its case and hadn't gotten to the phone. Strangely I had been thinking of replacing the case only a couple of hours earlier. Was a decent enough case, only a tenner but lasted 2 years.
As it happens, my screen has developed burn in, I'm seeing a permanent ghost image of icons. I went to EE yesterday, they're going to send it to Samsung for repair as my 2 year warranty doesn't expire till March 23rd, so timing is fortunate.
Also, my contract renewal is up and I'm going sim only. I've been paying £37pm for unlimited calls and texts and 15gb data. Apparently I've averaged 5Gb a month usage so I'm going down to a 10Gb unlimited calls and texts tariff, will only cost £14pm. Great saving of over £20 pm.
Lucky escape then! My S7 is still going strong and will be two years old in May. No burn in that I've noticed and I'm struggling to think of any reason to change or upgrade it TBH.
You might as well do the same as me then and go sim only if you're not considering changing the phone, you'll save quite a bit of money each month.I'm with Sky on 'swap 12' so after 12 months the price went down anyway and next month is my final payment overall. Then it'll be £7.50pm for unlimited calls and texts and 8GB Data. Not bad!Yep, very lucky escape.You might as well do the same as me then and go sim only if you're not considering changing the phone, you'll save quite a bit of money each month.
