 - 6 Dec 2013
 - Nottingham
LOL you make me laugh, dude get a grip and move on your wrong its simple.but that is exactly what Jensen is stating. I think you are reading far too much in to what he said and conflating different points he raised.
He basicaly makes 2 claims:
1) Most monitors don't have LFC and a sufficient operation range, or otherwise require new firmware or such that it isn't plug n play. Therefore, out of the 400 monitors most simply don't make the cut, regardless of an AMD of Nvidia GPU. Nvidia is fully entirely to say these monitors don't work under their own definition.
2) There are flickering issues, contrast, backlight issues and other bad behaviors when connected to a nvidia GPU, many of these issues are evident with and AMD GPU as well. Therefore, Freesync doesn't work universally. When Nvidia certify a freesync screen then the user has a guarantee.
It may be that AMD makes far more driver hacks to try and get badly behaving freesync monitors to work better while Nviai's freesync support uses only the exact standard. If monitor manufacturers are not following the standard exactly then Nvidia doesn't have to spend resources making fixes . it would be better if the monitors were made to be compliant. nvidia's certification might urge manufactures to be more careful with their freesync implementation, and this will help everyone.
At no point did Jensen say Freesync doesn;t work at all on any AMD GPU on any Freesync monitor. Only some monitors just doesn't work regardless of the GPU. This is a hard fact.
Nvidia don;t stand to gain anything by lying about this. They have conceded to support Freesync, they allow freesync on non-certified monitors. They don't cliam freesync doesn't work, or doesn't work on AMD GPUs
