News just in!! AMD compute card with 16GB HBM does well in compute tasks!
All those graphs show is Vega 7 is a good compute card, which we already knew as it's a rebadged M series card..
No it's a repurposed package on a redesigned pcb.
Crap cooler too....uses a heat pad on the gpu die as the metal heat sink leaves gaps ....
All on a 700 quid plus card...
Way to go AMD![]()
i think the guru3d review he only gained 2c by changing the pad to some high end paste, so the pad is probably equal or better to a lot of garbage pastes/applications. my personal wtf are u doing thing is the shroud where it says radeon being so huge its stupid :/ blocking airflow.
The logo was dumb, they could have made it smaller so that entire top section would have had the same gap for air to escape instead of it blocking off an air vent.
Indeed @Vince and myself have the overclocking well underway compared to most reviewers attempts, come join the fun XDHere ya go. He doesn't go into much detail, I think you'd get more from people in the owners thread here who seem to be on top of it.
Looks good!
A single fan cooler would never be enough to handle the radeon vii so it is what it is.
A design with two smaller turbines on the far right/top right part of the PCB, and heatpipes going from the large Vega 20 "vapour-chamber" directly to the left, connecting with the ports plate and transfering the heat directly to all the metal section of the chassis will keep the Vega 20 cold as ice. I promise you![]()
\You already talked about this the other day, if it was as easy or as effective as you make out it would have been done a long time ago. Just because we only see 3 main cooler designs from companies (blower, axial and aio) doesn't mean that behind the scenes they haven't experimented with other options.
I want a product which they sell to me, and I see it. What they do behind the scenes you can't know. Maybe they never did it.
Just done this in paint, not sure why they didn't go with this, just takes them to move the logo forward slightly and take out a piece of the aluminium.
Maybe you should apply for chief cooler designer at AMD. all the top air coolers are triple fan design
Now that would have been better, a smaller logo with better heat dissipation.
Nvidia did exactly the same thing with the turing coolers, the geforce logo tapered in heavily blocking off the fins and minimising the amount of space that air could be funneled through. Though they done it at both the top and bottom of the card which was doubly dumb.
