Pic: Your desk...RIGHT NOW
New desk and newly decorated office.
Do you have really long arms? Why is your coaster the furthest possible place from you? Pls go.
Had a play with rainmeter and changed my wallpaper.
I'm toying with the idea of getting a desk mat, but I'm not sure I will like black since it's shows up all the dust.
The Dell 27" 1440p goes back today. I couldn't live with the inferior text quality coming from a hiDPI laptop. So I now have a 27" 4K LG (27UK650) running with a 150% scaling and it looks so crisp.
Also picked up a hook to hang my headphones on under the desk, keeps the desk clutter free.
desk_setup_feb2019-1jpg
desk_setup_feb2019-2jpg
desk_setup_feb2019-3jpg
desk_setup_feb2019-4jpg
desk_setup_feb2019-5jpg
The length you have gone to to have a clutter free desk....then you have a wired keyboard? :p
I know :( the thing is this keyboard is perfect, and there's no wireless equivalent!
Tempted to drill a hole and put in a grommet close to the keyboard.
Don't get me wrong, the whole setup looks fantastic. But I think the cable of the keyboard just dogs it tbh. The problem with drilling a hole for the keyboard is the limitation of moving the keyboard if you ever want to. There is no going back from that.
I think a logitech K780 would look great on there FWIW :)
It would need to be smaller. A Logitech K380 would have been an option, however it's a downgrade in terms of:
- no gateron brown switches
- no PBT keycaps
- recharging keyboards :(
- no back light
- not white
Desk is so small for what you have on it :(
It's as big as it can be, my office is now smaller since having the loft conversion and having to make room for a new stair case. 160cm is the max, and it's got 2-3cm clearance on each side.
I’d take the PC off the desk, will make a big difference
It won't make any difference :p the space would just be empty, I don't need to put anything there.
Also don't forget I'm using a standing desk so all the extra cables running from the tidy under the desk to the case would be intense.
It would help it look less cluttered though as you’ve got a lot of stuff on a small desk. That’s all I meant
Yea I get what you mean. I prefer my PC on my desk for a few reasons. I did try it on the floor a while back with my last build and it looks good.
