Do you have really long arms? Why is your coaster the furthest possible place from you? Pls go.
Had a play with rainmeter and changed my wallpaper.
I'm toying with the idea of getting a desk mat, but I'm not sure I will like black since it's shows up all the dust.
The length you have gone to to have a clutter free desk....then you have a wired keyboard?![]()
It that wrist wrest a block of wood?
Don't get me wrong, the whole setup looks fantastic. But I think the cable of the keyboard just dogs it tbh. The problem with drilling a hole for the keyboard is the limitation of moving the keyboard if you ever want to. There is no going back from that.I knowthe thing is this keyboard is perfect, and there's no wireless equivalent!
Tempted to drill a hole and put in a grommet close to the keyboard.
I think a logitech K780 would look great on there FWIW![]()
Desk is so small for what you have on it![]()
It's as big as it can be, my office is now smaller since having the loft conversion and having to make room for a new stair case. 160cm is the max, and it's got 2-3cm clearance on each side.
I’d take the PC off the desk, will make a big difference
It would help it look less cluttered though as you’ve got a lot of stuff on a small desk. That’s all I meant
Ah well. I tried
You are cursed with that cable forever![]()
One of these to make it nice?The drill came out, the mouse pad was dropped for now. Setup has almost reached power level 9000.
