I tested on the private beta so the open beta is the same dates (1st of March)Are UK beta dates different to that of US? Open beta doesn't start until 1st March here, would love to dive in and play this.
I really wanted to enjoy The Division but couldn't for some reason. Maybe I'll give this a go and see what its like on the 1080.
I had the exact same problem, but that was when it was first released in the bad state it was in. Played it again and finished it recently, well I say finished you can just carry on. Anyway this time around I thought it was a very good game, can't wait for 2. My 1070ti plays it perfectly btw, so you will have no issues at all.
Running a 1080ti and a 9900k with everything on max (nothing reduced) in Div 2 beta I was getting over 100fps consistently so you should be fine.I'm about to launch TD1, I've not tested it on the my new GPU yet. I'm running 8700k @ 5Ghz, EVGA 2080 ti XC Ultra (2050Mhz core and 8000Mhz memory OC) and a measly 16gb ram as I still don't see the need for 32gb.
My display is an ASUS ROG PG297Q so it would also be nice to be close to the 144fps mark as possible. I'm going to assume TD2 will be that bit more demanding with the changes and upgrades to the engines.
1080p / 240hz screen with every setting maxed as high as it would go. No oc on the 1080ti. Based on that I would imagine on a 1440p you should be able to push 144hz with a 2080ti since it is quite a step up.Sweet, was that 1080p or 1440p? I launched TD1 and I was getting around 100fps with my setup an hour ago.
Hum. Really annoyed that I miss TD on sale then as at that price it would have been worth picking up if it morphed into a better game.I had the exact same problem, but that was when it was first released in the bad state it was in. Played it again and finished it recently, well I say finished you can just carry on. Anyway this time around I thought it was a very good game, can't wait for 2. My 1070ti plays it perfectly btw, so you will have no issues at all.
Download speeds are shocking I presume their server is being hit hard.
44.52gig download.speeds were fine a few hours ago. If you haven't deleted the private beta, open beta is about a 14gb patch.
44.52gig download.
Downloading at 256kbs![]()
don't know what's up with that; really slow
(edit: just saw your latest reply, good
). Yeah, 45gb is the full download without having kept the private beta.i had no update needed from the technical test.
ps, does anyone know if the full game release (march 15) will need another full download or just a patch?
Yeah when i click on it, takes me to the open beta and the preload is all greyed out cant download anything, so wonder if its when it goes live?
How do i do the update. In installed games it is there but greyed out no action can be taken, in the new open beta tab, there is no preload/update button.![]()
