Hi all, I am after a bit of info, I have owned a sapphire pulse 56 for about 2 months and generally I am very happy with it however I have an annoying issue where after a while gaming and I tab out and back in the GPU stops being utilised correctly and framerate drops and stutters and the only way of remedying the issue is to reboot. When it happens the temps drop from around 68 to about 50. I am using wattman to undervolt but it makes no issue if I leave wattman on standard. I have also tried overdriveNTool but it still occurs. I have also noticed that I can adjust any other pstate fro the memory other than P3 (is this normal)?
Any info would be really useful as I am really loving getting back into PC gaming but things like this remind me why I had switch exclusively to Console.
Cheers Sam
It could be one or two things-
1.What GPU did you have before the pulse did you install it in the correct way?
2.Is your CPU overclocked try running it at stock along with your GPU?
3.Drivers try using a earlier version than what you used when you first installed the GPU.
I have a powercolor dragon and can only adjust state 3 only on memory.
A console is plug and play where as a pc is a bit more involved to run and maintain, its a learning curve it never stops.
Let us know how you get on.
