Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Joined the Gyeon stuff to test.
Are you me?![]()
I use Chemical Guys VRP, which is very similar, though I use it neat and apply with a sponge pad. You can knock the shine back quite bit by rubbing with a microfibre, but it leaves the tyres nice and black and natural looking afterwards.I find PERL diluted 1:1 makes really good tire dressing, just spray it on.
The wetcoat looks really interesting too. Just spray on a wet car and voila. Sounds too simple to be true!
i've tried products like that before, one i tried was carpro hydr02 and that was very impressive, super easy to use too.
didn't last long but that's not the point I guess.
I used it as top up/sealant between washes, it was so easy to apply even compared to spray wax.Do you use it on bare paint or can you use it on top of hard wax?
I tried it for the first time week before last and just sprayed it on to more or less bare paint after the decon of winter, didn't last long in the sense that the car is dirty again but water still seems to be beading okay a week and a bit later. Unsure if i really used enough though.
Apparently using it on top of wax is also fine, so might do collinite and wet coat next time, or just another wet coat!
Sounds like Bouncers Bead Juice, awesome product.That's the appeal. Wash your car, but before you dry spray on some wet coat a panel at a time and pressure washer off. Once the car is done dry as normal.
Thanks for the input btw. The reason I said Halfords is because I had vouchers I needed to get rid of. I sorted the black spots on the roof and the tree crap on the weather strips with an APC and a brush, but i need to sort the exhausts. It's duel exhausts and they're completely black with what I assume is carbon(iinside and out), am I okay using a metal brush without ruining the exhausts, but what's best to break it down?
I’m thinking the other way, because if you look at their other silicon products like the MOHS, it comes with it another layer which you apply on top of the so2. So I’m thinking Wetcoat and then some form of spray wax or like Sonax BSD for a quick detail.
Just tried out the Gyeon leather cleaner on my drivers seat, very easy to use and evaporates to leave a nice clean surface. Just used a MF cloth. I then applied a coat of Gyeon Leathercoat, which again was easy to apply. It needs 2 hours minimum to cure, it'll have 2.5hrs before the car is used. When I left it, there was some streaking on the leather and I could see the product a little, but lets see what it looks like in a few hours. I did run a clean MF cloth over leathercoat to see if that affected the streaks, but I guess it has started to cure already because it didn't make any difference.
I'm pretty confident the streaks won't go, so I either used too much or the MF applicator had some residual product on it. I'll give it another ago during the week.
