But for those who've had one for the past 10 years, it's amazing![]()
I hope you are upgrading when ryzen 3000 chips are out otherwise that 2080ti you have wont be a happy bunny.
No argument with that, yesBut for those who've had one for the past 10 years, it's amazing![]()
I've just priced up an X58 system
i7 980X = £80
ASUS SABERTOOTH X58 = £125
12GB DDR3 = £35
£240, there are more expensive Boards and Ram and cheaper but if you're going to overclock these components to get the performance out of the system i figure you're not going to want the crappiest stuff.
If what you are looking for is good performance for little money yeah its not bad but these components are 10 years old, how trustworthy is the longevity and reliability of these components?
The thing is Intel are no longer competing with themselves in their older platforms, for me the argument that "Intel are gimping their older platforms through planed obsolescence" doesn't make any sense, smart savvy people who look for performance bargains are not going to be looking at Intel's brand new hardware.
Ryzen 1600X = £150
Asus Prime B350-Plus = £80
16GB DDR4 3200Mhz = £130
£360, yes its £120 more but its all brand new with warranty and very high standards of productivity and gaming performance. Intel's current performance equivalent to that is a 9600K and that's £270, £120 more than the 1600X and £30 more than the whole X58 System i priced up.
Yes Tech City need to change their message to stay relevant instead of moaning about it and throwing around conspiracy theories.
Are you after another bonus for AMD hahahaha
Seriously tho who would buy a 980x you have just picked the most expensive to make your AMD trumpet sound better.
So let's price one up properly?
5650x £18
Mobo (almost any x58 will do) £50
Ram £35
Now that's better bang per buck, no?
Grow up...
If you can find a decent one in good working condition. X58 mobo's are like rocking horse poo these days.
Bore off? Same old same old pal. Always going on about how good AMD are. It's a thread about a Xeon and you still make crap up and talk about the most expensive none Xeon CPU for this platform. It's childish.
To his defence he was not aware you could buy the cpu for cheap as chips. He was under the impression that it would cost £100+ for the cpu which is correct and not correct, some of the more expensive xeons like the X5690 are fetching £100 on ebay. Hence his analysis is kind of correct under those assumptions, it would be more prudent to and better to buy a 6 core ryzen build. But if you can get the whole lot for £100, like cpu, mobo and ram then its still a platform that can perform and good as a budget build anything more then it might be worth saving for better system, specially when the new AMD 3000 series cpu are released. I did however mention that you can get X5650 for £12-£15.
For anyone who has this system then the upgrade is a must. Now you can even install bootable Nvme and USB 3 via add in cards but still, the X58 platform as been one amazing workhorse, nothing like it has lasted so long and performed so well.
He's very aware! He know a lot about computer tech, he just can't resist a chance to give the AMD trumpet a quick blast. It's been going on for ages now.
This is the overriding point. If you can get a decent overclock out of it then it still performs well compared to modern budget build.For anyone who has this system then the upgrade is a must. Now you can even install bootable Nvme and USB 3 via add in cards but still, the X58 platform as been one amazing workhorse, nothing like it has lasted so long and performed so well.
Has anyone plugged a new RTX card into their X58? Just curious if there are any issues.
I tried a 2080TI and it really is a bottle neck, 1080Ti is the limit with the system and even then its holding the card back slightly at 4.4ghz. If its temporary then no problem and if you are playing games and you find that the frame rates are ok then no problem but to get the best out of it you really need something faster.
I currently have a 1080Ti in mine and its doing fine with every game I throw at it @4k.
I've used a X5650 at 4.5Ghz with a 1070 and it still performed well. Going from a 760 even the likes of a GTX1060 would be a large performance increase at 1080pThat's good to know. I was thinking of squeezing another 12 months out of my 5650 Xeon @4.4Ghz currently with a GTX760 card which handles everything I can throw at it but then again I game at 1920x1080. Was thinking of upgrading the 760 to something beefier but wasn't sure what.
