- 21 Sep 2018
Not stable.
You did not say it has to be. I'll just speculate like most here. lol
Not stable.
How? depends what they are measuring, Rome has 2MB L3 per core
By that measure the 8 core would have 16MB, the 12 core 24MB and the 16 core 32MB
which is whats listed.
AMD have stated that the µOP cache has been enlarged (to what they've not said), the size of the cache on Zen was 2,048 entries (2MB per core), each entry is one addressable memory location so technically they could've increased those without increasing the amount of cache but that would mean the memory would be divided rather oddly (IIRC most memory typically address 1024 byte sections at a time).
(Heinz)
There is no mechanism to directly access L3 of another CCX.
What is misquoted as cross CCX latency in tomshardware is a round trip to DDR4 and back. (check own L3, check main memory, flush other CCX L3 to memory, retrieve data). That is why memory speed affects this metric a ton.
Infinity fabric between two CCX exists so that they can share the memory controller. There is no cross CCX communication except going to shared memory controller (on another chips memory controller in case of Threadripper and Epyc).
Yes, I agree some however some are not very forth coming with this sadly.They're free to disclose anything they don't agree with in the reviews, so it's down to the reviewer, mostly. If the narrative makes sense, then they'll go with the flow. Being humble is the best policy, especially when it comes to the deeper stuff.
I remember someone claiming that Zen wouldn’t even do more than what was it? 2666MHz?![]()
I really hope so, bud....begins with a G ....
Yeah and now he's claiming what he said was entirely different.
tbh this forums is pro amd. look at some of the thread titles. amd this that . but if you title it intel faster than amd it would be changed or removed.
how many intel fans have changed to intel for eg. a lot of people here just cant post without biased. then if you say that its because you are biased lol.
Very sour grapes indeed.
an excrement
excrement excrement
I believe I said Zen wouldn't do 3866 on the memory side, and it didn't. Still doesn't, in fact on current gen. Let's not do this again Humbug, just engage in the speculation and discussion, please.
Just admit that you was wrong and then everyone will stop badgering you about it and get back on topic.
To be honest, I wasn't expecting so low wording and expressions from a user who I had generally respected a lot...![]()
excrement poster is a forum friendly way of saying ####poster.
You weren't around to see that ####posting.
Yes, I agree with everything, except that a core on one CCX can read from L3 of another CCX directly. Even in your quoted example (a very thorough review), latency between dies is for Zen is higher than latency to main memory.That's not entirely correct, all the L3 attached to each core is handled as a single large pool (Link 1, 2), the memory speed effects latency because IF (the data fabric part) and the memory controllers share the same clock domain (data crossing a clock domain introduces latency), and lastly there are 2 four core CCX's per die so you get a latency jump mainly when passing data between physically separate dies, having said that the latency issue has been blown out of proportion IMO, when testing was done Ryzen was found to have lower latency than Intel between cores on the same die but higher when it was between dies (40ns vs 80ns for the former and 80ns vs 140ns for the latter), neither of which you should really notice unless you're constantly bouncing data between cores.
We've done this before, dude. Couple this with the fact nobody has yet to get 3866 stable, which you proclaimed not to be true, either, I don't think anything else needs to be said. Let us move on.
https://forums.overclockers.co.uk/posts/30430250/
How and why could that be if not because it goes through the main memory, using DDR as LLC (last level cache)
You sound like you're actually trying to convince yourself - don't think anyone else will be swayed by your revisionism. You have a proven record.
