Here is my Huawei P20 Pro
What clock/weather widget is that?
Clock looks like the standard Google Time widget...weather one I don't know.
Are you sure you're looking at the same image?
Also, what's considered the best method of hiding status bar icons like battery icon, cell signal etc?
It was a preset for some app, I can't remember the name of it. I'll try and track it down for you.Are you sure you're looking at the same image?
I'm using the Samsung widget now!
Using Microsoft launcher. Need to find a nice icon pack now.
