- 3 Nov 2010
Thanks. It's the non carbon version.
I can't work out how to get the screw out as it's just turning the standoff below. There does not seem a way of tightening the standoff and I can't mb out as the one screw is turning the standoff below mb etc
No onboard GFX with your Ryzen CPU.no picture on my tv.
You've used one of the the sys_fan 1, sys_fan 2 etc?..I have plugged them into the correct headers
The motherboard header supplies them with power. But the settings in 'Hardware Monitor' may have them set to zero rpm when below your present system temp. You need to go in and check the fan profile for each 'system fan' (sys_fan) your fans are connected to.Do fans need power as I only have them plugged into mb.
I don't install motherboard suites/utilities - so i use BIOS for things like this. If you haven't installed it obviously use the BIOS - even if you have you may find playing with the BIOS a useful exercise in familiarising yourself with the enthronement.just need to work out how to sort out a fan curve then i am good to go. is it better to use the bios option or MSI command centre to sort out the fans
I recommend downloading and installing the latest BIOS - if it's not up to date - for memory compatibility and more BIOS features for overclocking (notably offest). *Be sure to update the BIOS via the BIOS using a USB pen drive.also i would like to apply a small overclock to the CPU. does anyone have a suggested guide i could look at - hopefully want to see if i can get my CPU at 3.9 or 4 ghtz
