Windows 10
If I use the latest ISO of W10 from MS will it be build 1809...? I see no working links if I wanted to dl the 1903 build.
Thanks.
I've been using 1903 for ages, since last official build. It's rock solid. If anyone wants the UK ISO I'll host it. I'll be assuming people want Pro?
Which version is it and where did you download it from? There are plenty of sites where you can legally download ISO images, so I can't see you linking to your source being a problem.
It's MSDN 1903 business editions UK. If you want, I can strip the ISO so it's just Pro. Probably save a GB or so.
Going to update my PC, any fresh download links as the one on the previous page don't work. Unfortunately I deleted the ISO I did have.
Edit. Never mind, Time Machine to the rescue.
Do you happen to know if yours is 1903 build 18362..?
AFAIK that will be the intended release for the 1903 update.?
I take it that the ISO you kindly shared also contains the Pro x64 build.?
Thanks
Thanks
I will check for you. The release date was April 18th. It contains all business editions (Pro, Pro N, Enterprise, Ent N, etc)
It's come up as 10.0.18362.30
ah.
The latest build that I have known to be the release for the up and coming update is build 18362.86.
IIRC there was even another build in between, something ending in like 53..?
I have found a place to download it from.....
https://uupdump.ml/
I have just downloaded build 18362.86 for ENG GB Pro edition x64. 18362.86.
Other editions are there.
ah.
https://uupdump.ml/
Yeah 53 went to 86 but it's only a KB. It was installed within about 30 seconds of the .30 build hitting the internet :D
