I did a clean install on my new system on the 30th and this was 1809If I use the latest ISO of W10 from MS will it be build 1809...? I see no working links if I wanted to dl the 1903 build.
Thanks.
Which version is it and where did you download it from? There are plenty of sites where you can legally download ISO images, so I can't see you linking to your source being a problem.I've been using 1903 for ages, since last official build. It's rock solid. If anyone wants the UK ISO I'll host it. I'll be assuming people want Pro?
Upload it as is, I'll take a look. Does it also have Enterprise?It's MSDN 1903 business editions UK. If you want, I can strip the ISO so it's just Pro. Probably save a GB or so.
Do you also have the 32-bit ISO?Available here for 30 days
Do you happen to know if yours is 1903 build 18362..?
AFAIK that will be the intended release for the 1903 update.?
I take it that the ISO you kindly shared also contains the Pro x64 build.?
Thanks
I will check for you. The release date was April 18th. It contains all business editions (Pro, Pro N, Enterprise, Ent N, etc)
Thanks.
I believe that the build number is 18362.86
It's come up as 10.0.18362.30
ah.
The latest build that I have known to be the release for the up and coming update is build 18362.86.
IIRC there was even another build in between, something ending in like 53..?
I have found a place to download it from.....
https://uupdump.ml/
I have just downloaded build 18362.86 for ENG GB Pro edition x64. 18362.86.
Other editions are there.
