I should be getting a call back soon to book mine in.
No GT86 as a courtesy car though. They have a Lexus CT200 or if that's not available a NX300H.
Odd courtesy cars, was expecting Toyota's still like the Corolla! Not sure if I'm a fan of the Lexus interiors, they always look so bulked up inside
Who here has had the final drive changed to 4.67?
It's supposedly a good mod in your scenario on an auto box, shaving about a second off the 0-60 time.
Manual is a different story unless you do hill climbs, not worth it if it's a road car generally if it's a manual.
From what i've remember reading on 86group forum is if you go FI on auto you're at the limit of what the gearbox can take. Not like manual where you can change the clutch and flywheel to handle the torque.
For auto I'd be more tempted to supercharge rather than turbo unless you're planning on limiting the boost. The auto is capable of taking forced induction but the torque needs to be linear if you want higher power.
Stage 1 turbo setup should be good for 50-80hp increase I believe so that is still good gains and car still being light it be a weapon against FWD turbo cars with similar power straight line speed..but on b-roads and track definitely say bye bye to FWD compatriots.That is correct. But I'm not looking for a 300bhp beast. And because I have dialysis in my left arm, driving a manual is not an option for the next couple of years.
This is why I contacted Tuning Developments to find out what they recommend, and they said a turbo with an automatic transmission cooler works well.
Stage 1 turbo setup should be good for 50-80hp increase I believe so that is still good gains and car still being light it be a weapon against FWD turbo cars with similar power.
