Both are good kits.
I'm firmly in the camp that a PC isn't meant to lit up like a Christmas tree (but everyone to their own, as Jay would say... I digress lol).![]()
How is that possible?So on all x470 and B450 gigabyte boards the f40 bios update enables PCI-ex 4 with ryzen 3000 chips![]()
MAGIC, HARRY !How is that possible?
The bit on the motherboard is literally just copper connect linking the CPU to the sockets, the BIOS is just the option to tell the CPU to run the PCI-E controller in gen 4 mode.How is that possible?
There you go ^ all the magic ruined with cold hard reality lolThe bit on the motherboard is literally just copper connect linking the CPU to the sockets, the BIOS is just the option to tell the CPU to run the PCI-E controller in gen 4 mode.
Top pciex 3.0 slot will be 4.0 so using half the lanes it normally would the rest 3.0 on the other slots, I don't know what this means tbh I can't wrap my head around why this is good, it just SOUNDS good to my earsI would be surprised if it was Gen4.0 to all sockets though. Perhaps just the top 16x socket and maybe one M.2 socket? X570 boards are expensive due to the extra work required for signal integrity.
Nah, either you'll get 16 gen 4 lanes if you have a gen 4 GPU in there, if you have a gen 3 GPU it'll default back down to gen 3 and use all 16 lanes again.Top pciex 3.0 slot will be 4.0 so using half the lanes it normally would the rest 3.0 on the other slots, I don't know what this means tbh I can't wrap my head around why this is good, it just SOUNDS good to my ears
What was that new 3dmark test that used pci-ex4 they were running at computex, navi uses pcix 4 ? how and why was that even necessary to show against a pciex 3 card in that benchmark, this is super confusing
But how can they possibly show that it's better in any way, how can bigger numbers come out fam? if the card stuck in a pci-ex 4.0 slot cant use more bandwidth that a 16x 3.0 slot? im confused cuzIt was to show that 4.0 is better than 3.0, nothing else. Bigger numbers, innit?
I've asked in the memory sub, but is this worth buying?
Or is there a risk it won't work or a risk something better comes along.
https://www.overclockers.co.uk/team...3200mhz-dual-channel-kit-black-my-08l-tg.html
