AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
1 Mar 2004
Kent, UK.
Looking forward to the reviews, hope we get a breakdown of how the RAM frequency affects the performance of the CPU. I was getting some G.Skill 3200 Cl14, but think I will wait and see now.
5 Oct 2009
Spalding, Lincs
Both are good kits.
I'm firmly in the camp that a PC isn't meant to lit up like a Christmas tree (but everyone to their own, as Jay would say... I digress lol). ;)
I'm not going for a full RGB build, however I do like the idea of being able to use a few items for some ambient lighting to suit a theme. I have no need for RGB fans doing crazy rainbow patterns!
Caporegime
8 Jan 2004
Rutland
The bit on the motherboard is literally just copper connect linking the CPU to the sockets, the BIOS is just the option to tell the CPU to run the PCI-E controller in gen 4 mode.
Yup, if the traces are of adequate quality there's no controller on the mortherboard, it simply has the traces from the CPU to the PCI-E slots.
26 Sep 2017
In the Masonic Temple
I would be surprised if it was Gen4.0 to all sockets though. Perhaps just the top 16x socket and maybe one M.2 socket? X570 boards are expensive due to the extra work required for signal integrity.
Top pciex 3.0 slot will be 4.0 so using half the lanes it normally would the rest 3.0 on the other slots, I don't know what this means tbh I can't wrap my head around why this is good, it just SOUNDS good to my ears
Don
7 Aug 2003
Aberdeenshire
Nah, either you'll get 16 gen 4 lanes if you have a gen 4 GPU in there, if you have a gen 3 GPU it'll default back down to gen 3 and use all 16 lanes again.
Caporegime
24 Dec 2005
Autonomy
