Caporegime
- 1 Dec 2010
- Welling, London
In that case, 99.9%.Its got about 7 players.
All we can really do is wait for reviews; from what AMD has shown they've made some drastic improvements. Although GTA V another game they're usually poor in, only showed an 11% improvement compared to the 2700X with a 3800X.
I hear you but surely you can squeeze another 10% from that CPU? I'm on 99/98% from each 1080ti in SLI 3840/2160MSAA 4x so surprised you're CPU limited in GTA 5. What's your mem speed out of interest?
Then again, according to their slides that allowed them to match Coffeelake performance, despite having a lower clock speed.
Who knows how Arma 3 will handle Zen 2 until reviewer and users get their hands on it.
I'm running a 5820K, so itching to upgrade myself; and my CPU is definitely holding back my GPU in GTA V alone, seeing around 45-57% GPU usage at best, while running 3440x1440 with all settings maxed bar MSAA only set to 4.
While I'll gladly agree that there's games that'll run better on Intel than AMD because Intel has the core for core performance advantage. I must interject that any game which is running 30-40 FPS on a top tier set up is at fault, not the hardware.
Well yeah the code is clearly bad for that to be case, I never said otherwise. But just that different hardware will run that code better than others. I dont pick games based on how it runs on my PC, I pick games if I like the game.
There are sometimes 9 or 10! Very few games are really CPU limited before GPU limitedIts got about 7 players.
With both processors running with DDR4-2133 memory, it seems that AMD is catching up to Intel in single-core performance. Nevertheless, the Core i9-9900K is still around 1.09% faster here, according to the leaked numbers.
The multi-core results, on the other hand, are in AMD's favor. The Ryzen 7 3800X beats the Core i9-9900K by up to 4.95% in multi-core workloads.
why are they running an amd at 2133 ?!
geekbench is more relevant to gaming performance than cinebench just to point out.
cinebench tests rendering performance.
This is what geekbench does.
http://support.primatelabs.com/kb/geekbench/interpreting-geekbench-4-scores
People assume cinebench is some kind of god as all their favourite reviewers use it, they use it not because its meaningful and accurate but because it showcases new products well as it really favours logical threading and higher cores. Thus showcasing both new amd and intel flagship products well.
Cinebench is floating point which is gaming performance.
Cinebench multi isn't the best way to test realistic gaming performance, you can extrapolate using it, but best way is single threaded in Cinebench and extrapolating.
Name a CPU that applying that rule doesn't work.
I'll never just take a multithreaded cinebench result to mean anything without context, as context is important.
But Cinebench is FPU heavy, which is what gaming is.
And now that Intel is losing in it, they want to sweep Cinebench under the rug and pretend that it doesn't mean anything. Intel trying to manipulate what benchmarks should be used. Oh how some things never change.
Also, for the record, R15 is SSE2, while R20 can take full advantage of AVX up to AVX-512.
Games like Project CARS and Overwatch already use AVX instructions. It has taken far too long for the software to catch up to the hardware in this regard (mostly due to Intel artificially segmenting AVX to the more expensive products, but even then, it has been 8 years in the making).
Actually the reason its 2133 (just read on there), is tomshardware searched for the results, there was only 2133 available for the 3800X so they then looked for 2133 for the intel chip to try and keep memory i.o equal although I expect the amd system will still be having better i/o for cache and between cores.
I havent heard of intel wanting cinebench gone, note that geekbench still shows AMD making huge gains, so what I posted is nothing to do with AMD vs intel.
yeah just looked at it and its just more leaks, thought toms had jumped the gun at first and run their own tests at 2133, guess its back to waiting for the 7th again![]()
