There will be reviews on launch day of that board, I've sent out the samples but can't confirm which ones yet.
Yep, we are finally going to have stock of the ITX version on sale at launch too....
Yes, top down cooler is the plan with a custom mod VRM heatsink so flow is forced onto/through it.
Just need to see how much room I have to Tig weld some alloy onto the heatsink.
Have to see how much room there is as it's going to be tight, can't find a pic without the back panel connector plate/cover.
From that pre-view, i may as well pull off the heatsinks for my 3700X/3800X.
That and my A. C Clarke, 2001 monolith would block out the board's physical presence anyway. Coupled with the fact i still wouldn't have a windowi think the ITX version is 100% hidden as there is no space to see anything lol
Hehe, forgot about your 'Sylvanian Family' sized builds.@Plec lol. Not interested in the ATX sized boards![]()
Just looked at your thread/recent replies - looking expensive :/. Shame my guy isn't close to your area.I'll just have to work extra shifts to pay off the paint job on the car.![]()
Drop to a 3700X and enjoy the challenge with me - although i may cave and get the 3800X if it reviews considerably better...Still intending to get the 3900x - pending reviews
Yeah, that was the kicker - if i didn't move on boards quickly i would want the choice to stretch the cores of a 3950X.@Plec, 4 layer PCB and single 8 pin
Hey, you're gently bumping up my up upgrade path costs like you do with some spec me threads - you have your mooooore power head on!..@Plec grab him the Aorus 7 instead of the Carbon and you know he'll be set for any Zen chip you throw at him
£100 more but your rocking a better board, then Pro for yourself so your little ahead harware wish! and rock Zen2 for yourself, though you might find your son could be on Ryzen 3000 too....
Highly doubt it to begin with. Surely they'll start with selling separately to keep prices at max. Bundles always end up having some kind of discount.
So the Pro might be the cheapest (note, not cheap) if you want to drop a 16 core CPU in down the line?
A 2080Ti to run Minecraft - does not compute... (looks incredible)
@Plec ^^^ resale value![]()
I know how spec me members feel now - where's my 'Plec' who joins the thread and gives a revised build for compromise on power to budget ratio for comparison?X470 Aorus 7 is 8+4 pin and 10x 40amps so Pro tips it but guessing it'll be priced the same ...
Also Aorus 7 has 8 layer PCB , same as Xtreme x570 @Plec - all B450 are 4.
it's crap. don't do it.where's my 'Plec' who joins the thread and gives a revised build for compromise on power to budget ratio for comparison?
LOL - apart from my misguided visits to the CPU forum, i'm sure i'm more subtle than that (although, you did a pretty good Plec impression thatit's crap. don't do it.
