- 30 Mar 2010
- Exile
There shouldn't be any difference should there?
Dropped off my car and picked up my Corolla Courtesy Car today. I must say it's a great car to drive. Very different style of driving needed but once you get used to it (only took me around 10 minutes) it's so comfy and quiet.
Averaging 66mpg, not too shabby. It's the 1.8 Hybrid. It's nippy when you floor it but very dosile when you're <50% throttle, my only peeve with this thing is the fact the throttle above 40mph feels like it's on or off, with very little inbetween.
Wonder if you have to do slight run in period with the engine before abusing it.
Why?Are they stiffer springs? Because that will make a difference.
The year 6 service should include air filter, brake fluid, rear diff oil, oil and filter change and spark plugs for £400, so really you've only saved £65.
Probably skipped the dif oil thinking no one will notice. But it's an LSD so you can't really get away with ignoring it.
Day 1 Summary time:
So, the issues/annoyances I have experienced so far are listed below:
Not happy at all and need to think about writing a complaint asking for a portion, if not all of my money back. Will be going straight to head office should I receive nothing that satisfies me. Considering these are things I have found on day one I dread to think if there's anything else that may have been missed. Especially given the amount of engines that have gone bang after this.
- Coolant was nowhere to be seen, supposedly due to an airlock. Which absolutely should have been checked by themselves before handing the car back to me.
- Once I brought this up, they took the car in to "have a look" and dropped it off outside the door for me. Not being absolutely satisfied I decided to give it another check. It was now 3-4" above the "FULL" marker.
- Underside of the bonnet covered in oil/dirt with some scratching where paint has been removed. Presuming they have put this on the floor somewhere whilst they worked on the car.
- Increased noise from injectors or valves, sounds like tappets.
- Throttle Body/Inlet Manifold making loud electrical whine and scraping noise when actuating the throttle. May be there from usual but definitely comes across as being louder.
- Airbox no longer seems fully connected to the front scoop under the bumper.
- Air Filter has not been changed in the £335 service. Still dirty and remains in the car, this is in the service guidelines as due replacement every 3 Years/30k. This is the 6 Year service so should have been replaced.
- Car has been "Washed" and came out a lot dirtier than when I brought it in.
- Charged £171 labour for Rear Differential Oil which should be changed every 20k/4 Year. It's on 42k so should have been changed, but this is not on the description of "Goods / Services", rather just an Oil Filter, Spark Plugs and Screenwash that I didn't ask for.
Overall, if anyones near Newcastle/Sunderland area. Do not take your car to Toyota Wearside.
