the chance of an annoying fan at £240+ does give pause for thought - or in my case waiting for reviews.
July 7th OcUK forum members all-day activity:
What is PWM exactly?@Plec
Reason for Pro over elite .
Check out layout of PCIe 4.0 lanes ...
Almost sums up how B550 versions will be....
Should CUT the costs for the Elite and hopefully means Gaming X keeps its costs down !
@tamzzy
They redid it bar front glass. Allows ATX PSU and slight raise for more clearance with triple slow GPUs .
http://www.lian-li.com/pc-q39/
So tempting to cut the midway to allow dual 120s to be mounted in PSU chamber .
Also has USB C 3.1 port unlike the class version
ok, I thought it was something to do with fans as you get PWM fans. Very confusing when you’re not a techie.controller - First page give brief insight to how its Boards PWM/VRMs are set up
@EsaT is pretty clued up on it . Gigabyte taken a huge step being the first to use 16 channel controllers. Most use 8 or Multi Phase controllers which are an in between - Godlike uses this method but still is a Beast like its Xtreme rival!
Oh
Ok, one last simple one, whatever case fans I use, if I connect them to the motherboard headers (I think the master has 3), the motherboard will control their speed according to system temperature?to be honest, both are Pulse width modulation for electronics![]()
It's precisely what it "says on the tin".What is PWM exactly?
PWM fans use PWM signal from motherboard/fan controller as TTL control signal for their speed controlling electronics.ok, I thought it was something to do with fans as you get PWM fans. Very confusing when you’re not a techie.
Which case is this?CyberMedia
Which case is this?
Do you guys just connect your fans to the board or do you use a controller?
ITX board is spot on, best I've seen in a long while, just need the price now. @200 it's a instant buy...... think it will be closer to the 250 mark though![]()
Yes, it was. And it's a similar theme with the quality B450's too - not just here.
@robfosters - motherboard, and set the curve via BIOS - I don't install blaotware/RGB on OS, horses for courses etc...Do you guys just connect your fans to the board or do you use a controller?
TrueJuly 7th OcUK forum members all-day activity:
@orbitalwalsh would've thought so. £200 would be nice, but I can see the x570i to be £220
The Taichi, even with its god-awful graphic design is particularly appealing if on a budget - ~£180 - for now...
