AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
26 Nov 2009
I would wait for reviews - my main worry is peak VRM load of the Ryzen 9 at peak boost. Technically the Ryzen 7 2700X and Ryzen 9 3900X are the same TDP classes,so should be similar in terms of cooling and probably power consumption. However,looking at how the X570 motherboards are built,it could be a harder beast to run.
TDP and power consumption are two different things. 3900X will probably consume more power even though both have a 105 TDP.
9 Nov 2009
Planet Earth
I get what you are saying but you missed my comment on peak VRM loads. One of the advantages of better VRM designs is transients are handled much better,and looking at how the X570 motherboards all on average have much better VRM designs than a lot of B450/X470 motherboards, tells me AMD has pushed a higher requirement becuase of the 12C and 16C models. If the 12C and 16C at peak boost speeds draws more current than a Ryzen 7 2700X then it might cause problems. This is why I won't try and say a B450 or X470 motherboard is fine until we see reviewers test them with the Ryzen 9 3900X.
Apparently 5 GbE (not 10 as I originally stated), an OLED display, and an extra vertical M.2 slot. I'm just pointing out they're not the same and the price of one doesn't reflect the price of the other.
The last two bits won't add £400 to the cost of a motherboard especially if they are using a cheaper Ethernet chip.
It cannot be chipset pricing either as we are having sub £200 X570 motherboards too.
Asus are testing the market to see if they can get enough people to buy the Titan equivalent of a motherboard.
30 Jun 2019
Hi guys, I'm new here.
I'm probably gonna get a Ryzen 5 3600, or maybe a 3700X if single threaded performance is significantly better (upgrading from an i5 4440).
I've been researching if it's worth getting higher frequency RAM such as DDR4 3600. There's a review below, which shows significant peformance improvements in some games and other tasks below, but it's tested on an i7.
https://www.techspot.com/article/1171-ddr4-4000-mhz-performance/page3.html
There's also some benchmarks popping up that seem to show some improvement to scores, when using higher speed RAM.
I've been struggling to find a motherboard that's reasonably priced (say £100 or less) that supports DDR4 3600. The Asus ROG STRIX B450-I GAMING motherboard does support it, but isn't cheap in the UK.
I notice that some cheaper boards support upto DDR4-3466.
So I'm hoping someone can answer the following questions:
1. If I get DDR4 3600 RAM, will this work on a DDR4-3466 or DDR4-3200 capable motherboard, at the lower speed?
2. Are there likely to be cheaper motherboards that support DDR4 3600 RAM when/after the Ryzen 3000 series is released?
3. Do you think it's worth spending a little more to get DDR4-3600 RAM, or should I get DDR4 3200 RAM with a cheaper mobo?
Caporegime
18 Mar 2008
No serious need to buy 3600 Kit, a good b-die 3200 CL14 kit will clock up well enough (3600 CL17 shouldn't be an issue), the problem right now is that there are new dies coming out and new kits being released that might be slightly better or have higher density for similar perf.
I think the best option is just to wait til the 7th roles round though, need some actual information.
There is reddit page that should be taken with a pinch of salt on quality of the 400 series wrt to VRM mainly.
Wrt to Ram speeds, its the CPU that matters well before the MOBO does.
16 Sep 2018
I think Zen 3 will be the final Ryzen generation on AM4, which will come out next year. So yes, I completely understand your thought process, and agree for the most part. If you plan on keeping the system for half a decade, it would be worth getting a decent board, but there's no need to go overkill.
Personally I'd put my money on Zen 4 being the last AM4 chip, reasons being DDR5 and PCIe 5.0 probably won't be ready in time for a 2021 launch and running with the 7-7-7 theme they'll probably go with a 5-5-5-5 theme (DDR5, PCIe 5.0, AM5, on 5nm).
Caporegime
18 Mar 2008
Oof 5555 on 5/5, they have to do it.
19 Jun 2019
Leicester, UK
Look, I just hate “gotten” ok! It’s only creeping back into British English after being left for dead, due to people either being taught the wrong words at school or letting media influence affect the way they communicate.
The correct words.*
Absolutely. Zen 2 CPU TDPs are calculated at their base frequency, just like Coffee Lake.
Holy ****. PassMark has historically been ****** on Ryzen, so to see this means more than it may seem.
** Fully star out all swearing **
Going further into the three tests;
Code:
| Motherboard      | Gigabyte B450 AORUS M                                                   |
| Processor        | Ryzen 5 3600                                                            |
| Memory           | 2 x 8 GiB G.SKILL Flare X DDR4-3200; CAS 14 (8.75 ns) [F4-3200C14-8GFX] |
| Graphics Card    | NVIDIA GeForce RTX 2080                                                 |
| Storage          | 240 GiB Crucial BX500 [CT240BX500SSD1]                                  |
| PassMark Score   | 5,334        |
| CPU Mark         | 21,133        |
| 2D Graphics Mark | 750        |
| 3D Graphics Mark | 15,977        |
| Memory Mark      | 2,979        |
| DiskMark         | 3,278        |
| Memory           | 1 x 8 GiB Crucial Ballistix Sport DDR4-2667; CAS 16 (12.00 ns) [BLS8G4D26BFSTK.8FD] |
| PassMark Score   | 4,930        |
| CPU Mark         | 19,620        |
| 2D Graphics Mark | 753        |
| 3D Graphics Mark | 14,397        |
| Memory Mark      | 2,171        |
| Disk Mark        | 3,368        |
| Graphics Card    | Unknown, but scores low                                                             |
| PassMark Score   | 4,138        |
| CPU Mark         | 19,650        |
| 2D Graphics Mark | 717        |
| 3D Graphics Mark | 2,285        |
| Memory Mark      | 2,151        |
| Disk Mark        | 2,950        |
That confuses me, why is the intel chip at 3.6, surely those things can do 5? Which should give it about 40% more perf?
PassMark reports the base frequency and the maximum turbo frequency of the processor.
Welcome!
1) It should, but no promises. Reviews will be here in 8 days!
2) Yes. The B550 chipset will coexist with cheaper boards (no PCIe 4.0). Looking at the prices of these X570 boards, I think I may hold off to see what B550 boards there will be.
3) Looking at the data above, DDR4-3200 CAS 14 does appear to perform exceptionally well. Again, wait for reviews before making your final decision, but right now I would say unless the price difference is minimal, I wouldn't bother.
Now that you say that, it does make a lot of marketing sense for them to do that.
16 Sep 2018
Not really, AMD use TDP = (Load Temperature in Celsius – Idle Temperature in Celcius) / Thermal Capacity of Cooler.
Of course, as mentioned in that Anandtech link, the difference in TDP could just be down to the different coolers (stealth, spire, prism) that come bundled with each CPU, i doubt it but until we get some reviews we won't know for sure.
19 Jun 2019
Leicester, UK
It seems to be a change from Zen and Zen+, just as Coffee Lake was a change from the way it was calculated with Kaby Lake.
The 3950X has a 300 MHz deficit on the base frequency, but 4 additional cores. Unless AMD is using some absolute overkill cooler for these calculations (which they would have to reuse for even the Athlons, and would be highly impractical), then it makes no logical sense for it to be otherwise.
