Link something that gone from net ??
They took it down? ok.
I’m sorry can someone explain 9900k 95w and regular 9900k? Is one overclocked? It seems that the 95w reaches better min framerate than the other, is there a reason why?
Understand why they use 720p but its still pointless.![]()
720p low details, there is CPU testing and then there is taking the ****..
TBH I would like them to test 4K with 2080TI SLI all ULTRA rather than artificially low res/details. I prefer real World testing to arbitrary scenarios but either way720p low details, there is CPU testing and then there is taking the ****..
this doesn't look good.
It's the only way to test them properly but I'd include 4K.still fair , if your trying to rule out GPU interference .
but 1080p and 1440p is were everyone will look at. all knew at 720p intel would win .
we also know test was done with lower ram timings. now would like to see 3600hz used is both intel and amd, then both pushed to absolute max![]()
My world !!!real world, 2080ti in sli. what real world is that ?!
I tested with 1080p and 2080Ti on the benches I ran.
720P testing is fine but not at the lowest details, the CPU isn't doing anything at low details, with it a dual core has the same performance as an 8 core because anything that would make use of Multithreading is turned off, when you do that an i3 is just as good as an i9, its not a real test of the CPU.
turning off details is an incredible naive way of thinking about CPU game performance testing.
And again.....why do we never learn......? The Intel CPUs are running slower RAM too! 2667 and still smashing 3900/3700 using 3200 RAM.
Pi** poor yet again from the looks of things.
Significant improvement over the R7 2700X in every game they tested, but also significantly behind the i8-8700K and i9-9900K. These are all at 720p though so the gaps will be very much smaller at realistic resolutions. Also interesting to note that even at 720p, the 12-core is barely beating the R7 3700X in gaming. Definitely reinforces my gut feeling to go for the R7 3700X.720P resolution.
Now lets see the 3440x1440P results![]()
My world !!!![]()
get back to you're cupboard! Significant improvement over the R7 2700X in every game they tested, but also significantly behind the i8-8700K and i9-9900K. These are all at 720p though so the gaps will be very much smaller at realistic resolutions.
