Permabanned
- 28 Sep 2018
Tomorrow we get to find out why the 3800x even exists!
When you consider that desktop, workstation and server all use the same basic Zen dies that tells you a lot.Show me where Forrest Narrod did that. Doesn't even look like his job has anything to do with consumer ryzen products.
You are influencing someone who is spending hundreds of pounds based on something you've made up.
Also on you're other post. You have any evidence to suggest that a server socket change is in sync with a desktop socket change and vice versa? Or is that more guesswork presented as a 100% fact.
Then there's the fact that server is what really pushes the envelope in terms of performance and RAM speed is very important there.
On top of that, Zen 3 is a relatively minor die shrink of Zen 2 in one sense, so don't expect any massive changes if as stated directly by AMD that Zen 3 server is DDR4.
Why would AMD add DDR5 support to Zen 3 and go to all the trouble of validating it and then not use it in the platform that has the most use for it?
As for the socket, there doesn't seem to be any good reason for AMD to change it with Zen 3.
This is speculation but it seems pretty solid.
If someone is naive enough to treat a post on a forum by a random person as gospel and make decisions based on that without due diligence, then they have bigger issues that need to be addressed.
) they don't have that degree of confidence and are massively exaggerating. When we peel the evidence he posted back it is actually quite tenuous.boy, you've said itWell I certainly ain't the one promising him future compatibility with Zen 3 with 100% certainty when really all I have are some inferences from some comments on server products.
Only 14 more hours of bickering to go.
Oh who am I kidding.![]()
Somebody has the ryzen 3600
https://www.reddit.com/r/Amd/commen...t_d/et3h0y0?utm_source=share&utm_medium=web2x
Their is a bios lock so no overclock till launch day!
https://i.imgur.com/lNqmwkn.jpg
Hope for price drops and try to get a cheap 9900k. If there is such a thing.I'm still deciding whether I want to upgrade my main 9600k machine to Ryzen, or just slot in a higher intel on my Z390M. I like the idea of having x570, though, because it gives me the option of Gen4 SSD, and it's 7nm (hopefully Ryzen will finally run cooler than Intel, and I run Small Form Factor, so temps are important).
That link last page with 3600 at 4.2 ac and 1.4v at 70c, I wonder what cooler as it seems very unlikely a 12c part would sustain anything like 4.5 unless on water. That's unless he's using low end air.
It's 7/7 where's the lewds.
but unfortunately the world doesnt think we are as important as we do
usa has a fair few hours left before its the 7th
and its been said many times and confirmed by people that its 2pm reasle time for store and i belive thats when the nda finshes for youtubers also
14 hours is when the bickering truly starts.
Very true, I just can't wait for the "Well, Intel still the best for gaming!"![]()
I take it you don't own a current Ryzen then ? There isn't a cat in hell's chance that any AMD cpu released tomorrow will pull more power or current than previous gens. What will certainly pull more power and current is the 3950x released in September.
Wait, the guy said that its boosting to 4.2Ghz on all cores, and staying within 65w. I wonder if AMD have changed they boost from single core to all core boost?
looking forward to the cpu reviews, the mobo's not so much if leaked pricing is anything to go by, the masses will opt for x470 with a updated bios.
i've got the cash for the 3900x and at a push a extra £750 max for a board, so anything under that will be put to a 4000mhz kit of ddr4 ram form ocuk
