Why are people saying the 3800x is going to perform like 3900x it's just a 3700x with 100mhz extra?
A few things on this;
The 3800X should better than the 3700X due to "better silicon" but more so the default power limitations. The new boosting algorithm will go as high in frequencies as it can go within its constraints, no matter the amount of CPU cores.
The constraints are as follows:
- Package Power Tracking (PPT): The power threshold that is allowed to be delivered to the socket.
- This is 88W for 65W TDP processors, and 142W for 105W TDP processors.
- Thermal Design Current (TDC): The maximum amount of current delivered by the motherboard’s voltage regulators when under thermally constrained scenarios (high temperatures)
- This is 60A for 65W TDP processors, and 95A for 105W TDP processors.
- Electrical Design Current (EDC): This is the maximum amount of current at any instantaneous short period of time that can be delivered by the motherboard’s voltage regulators.
- This is 90A for 65W TDP processors, and 140A for 105W TDP processors.
i.e. the higher the TDP of the processor, the bigger the power package available by default. Though worth noting that board manufacturers will likely have a work around to the constraints.
These chips are clocked so high by default that further frequency improvements via the "Auto OC" feature are disallowed by the silicon fitness monitoring feature (FIT), due to the required voltage for higher frequencies being too high. So it'll be down to working around this to get more out of the chips. But really, it doesn't seem worth it.
				The Stilt said:
			Increasing the PBO limits (PPT, TDC & EDC) will increase them as far as FIT (voltage) will allow. Practically that means around 100MHz higher clocks (4.075GHz).
PBO does nothing to the single core clocks, since single core workloads are not limited by PPT, TDC or EDC.
The 3900X has a higher power package than the 3700x, obviously. However, more importantly the power package is split over two CCDs, spreading the heat. So whilst I think the 3800X will be better than the 3700X, I don't think it's going to perform as well as the 3900X, before you even take into account differences in cache.
Apart from maybe memory overclocking, this (in theory) will be better on a single CCD chip as 2 CCD parts (3900X and 3950X) should be more picky about FCLK, due to discrepancies in the CCD signalling as typically one CCD will prefer lower voltage than the other.
If the 3800X shows to on-par or better than the 3900X, then I think it would be safe to say that they are very much well binned and would expect the 3950X to be killer.
