AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
3 Jul 2019
what motherboard x570 do you recommend up to 400 euros for a 3700x or 3800x?
Msi meg ace x570
Gugabyte aorus master ........
15 Nov 2018
I feel like a **** ahah, I was getting really bad temps and throttling on my 3700x. Just realised the wraith prism wasn't locked in place. The lever was too the left not right so there was no pressure. I thought I had lost the silicon lottery big time, guess its time to rebench everything
28 May 2007
4350 all core + 3800cl16 stable :)
Moving to 4400 and off to work on car see how that goes
Very nice. Is that 1T 1-1 IF
16 Jun 2010
Manchester
That sir is a proper brain fart moment.
Glad you sorted it tho.
8 Mar 2019
@Lolik
Did you forget to uncap your framerate from 120 only the improvement at 1080p seems wrong?
Nope it basically was butter smooth with 2600x, 3700x manages to squeeze few extra % from 1080ti, but with my settings it is gpu limited. Just shows how we Really need upgrades to the "new and shinny" :D . From other point, when the whole your upgrade consist of just swapping cpu and costs next to nothing, temptation is unbearable;)
11 Jun 2003
Sheffield, UK
Yup 3800 1:1 but qas i said got better memory kit comming tomorrow could not resist 8pack 4133 so my mate is getting my kit i fork out extra and get upgrade :D
Would be interested how that goes. I'm one rung down on 4000mhz g-skill stuff (still good binned b-die).
Waiting a bit for things to settle and 3800X reviews to appear.
If placed get the 3800X's tomorrow though... I'm gonna be AWFULLY tempted to jump on the early adopter boat :(
29 Apr 2003
Cardiff
Looks like there's a problem with Gigabyte B450/X470 boards + Ryzen 3000. The NVME drive is not being detected so i guess you an use a sata drive or get a nvme to pcie adapter until there's a fix.
Permabanned
15 Oct 2011
Nottingham Carlton
forgot gow un fun normal cables are. But its cheaper build with compromises next year orr whenever my mate will cahne that 3600 to soem 12/16 core zen 3 :)
@GIGA-Man Well tomorrow ill have a look what Gigabyte changed in bios ect. Only thing I could complain is cpu 8pin tad too high so could not get aio with fans on top of this case but thats also kinda case fault :p . Deffo nice connector for front panell with power button ect. Can say even better than Asus one :) In general board feels much more SOLID than last Gigabyte one I was playing with. T
27 Apr 2004
I get my 3700X tomorrow so this will make for a good comparison when I run it again.
4790K @ 4.4GHz (all core), 16GB 1800MHz RAM, GTX 1080 Armor OC
1920x1080 Ultra Preset - 33.8 FPS
3440x1440 Ultra Preset - 32.3 FPS
1920x1080 High Preset (same as review posted) - 40.7 FPS
Note sure how Jacky60 is getting 53.7 FPS on that, I guess Arma is making use of those 4 extra cores.
Thanks that would be fantastic, I'll check my results but RAM speed and cache speed are both very important for Arma 3,
more so than most games, I'm on DDR4 3000mhz, 4250mhz cache.
Just got my system up and running, only thing I did right away was stick the RAM up to 3466MHz - everything else essentially 'out of the box'.
3700X @ Stock, 32GB 3466MHz CL16 RAM, GTX 1080 Armor OC
1920x1080 - 56.1 FPS (+38%)
Cheers
Permabanned
15 Oct 2011
Nottingham Carlton
Well I did Power Director rendering test on my small 35 minutelong project:
Time on 2700x@4250 47.22
Time on [email protected] 35.43
Thats what i need ZEN for... Gluing together footage from raves for My Youtube.
In the end Everyone ends up listening to psytrance hehe
16 Jan 2010
Earth
Cheers
That looks about right to me, it's good to know AMD are delivering again. It beats my 5960X, not by a huge margin but a win is a win!
27 Apr 2004
Steve says he has a hard time recommending the 3700X because they don't like recommending chips that are the 'odd one out', stuck in the middle while being 'very good at the things on either side' :confused:
That's like, entirely why the 3700X is the buy for me.
31 Dec 2006
Slightly odd conclusion from Steve... wonder what he's going to make of the 3800X lol! That's surely likely to be more the odd one out based on his criteria. The 3700X ticks many boxes for a lot of people I'd say, except for someone who's ONLY gaming and nothing else, more so if they're at 1440/4K. Otherwise, the 3700X does a lot right. For budget builds, the 3600 is clearly the way to go though, but that was never really in question.
30 Jul 2004
Auckland
Assuming his benchmarks are right - and he is pretty careful, the 9700k with the 8 cores is actually a very strong chip. I am super happy as I am going to be grabbing a 3600 to upgrade my 2400g and that is a really good uplift.
