Man of Honour
- 8 Nov 2007
- Outer Space
Thanks for the infoI do not have the waterblock any more. Sold it 8 months ago as I was using a reference board & cooler since October. (until the EK Predator decided to chew the filter).
Just leave 1 screw near the end of the board (to the right as you see it upside down). Mine was missing few screws, and because I used the original X bracket, uses 4 long ones with the springs and had 4 missing from the backplate.
So with the 4 longer screws on the X bracket, did you take the springs from the small screws with springs attached, as the springs didn't seem to want to come off the little screws?
