Hi all,
Long time user of the forums, first post. I just wanted to take the time to throw my experiences into the mix, if it helps anyone all the better...
I managed to get a clearance Vega 56 Pulse for £200.00 from OCUK. I got lucky with Samsung memory but it does not budge past 950 MHz. Comfortably I can apply a 1637 MHz core overclock with undervolting and a max fan speed of 60%. Resultant 100% load core clocks range from circa 1560 MHz to 1610 MHz game dependant. My total power draw as per GPU-Z is circa 206 watts on a Furmark load, and circa 180 watts for the several games I have tested, again at full load. In watt man my core frequency is set at +3%, and my voltage control is set at N/A, 900, 950, 960, 970, 980, 1010 and 1010 from state 0 to state 7 respectively. Max Furmark temps after say half an hour stress test are all well within spec, circa 60 degrees C on the core, 80 degrees C on the hot spot, every other temp is not even close to the thermal limit.
I can push my card to 1680 MHz with 100% fan speed and temperature becomes the only constraint (namely only the hot spot temp however). Diminishing returns become hugely apparent at anything over my aforementioned stable overclock however, I would not waste any money on after market air or water cooling for this card.
At £250.00 new in the UK this GPU beats the New Navi, RTX and RTX super cards solely on a pound coin per frame. For me this card takes the title from the GTX 970 for best performance for the money.
Dan
Dan
