3900x no stock anywhere and 9900K can be had for £400 now. Also the good Intel motherboards cost way less.
Just caved in and ordered a 9900K.
This. AMD released a statement about it on Reddit. Basically apps like HWInfo constantly wake the CPU to check the clocks, but once they go to deep sleep they - by design - shut off. Apps like HWInfo aren't coded to properly deal with this, so they continue to report the last known reading (eg 1.45v and max clocks) despite the core actually being off. The takeaway was use CPU-Z and/or Ryzen Master, both of which read the CPUs properly and give accurate readings for clocks and voltages.
Has Hwinfo been specifically confirmed as a problem ? The AMD posts on Reddit said monitoring software without naming names. The Hwinfo guy has posted a reply in hwinfo forums.The cores go to sleep and use hardly any power but every time hwinfo tries to read the speed and voltage of a core it wakes it up and it boosts the speed
Regardless of whether you're team red or team blue - this is why AMD being competitive in the market place is good for all!
https://www.hwinfo.com/forum/Thread-Votage-Monitoring-for-Ryzen-3000-Processors
I don't have any confirmation for this issue yet, but theoretically it's possible that HWiNFO might be affected. It might also depend on system configuration and what kind of/how many system components are being monitored.
If I get such a confirmation, I will surelyy look for some solution.
The post I read was by an AMD rep and mentioned hwinfo specifically. It included screenshots of CPU-Z and Ryzen Master and said to only use those two, at least until other apps patch and fix the issue.
Tempted to do the same although I do want a 3900X.
Get a 3600 as a stop gap until 3900x comes in stock
Na, I would rather wait. I'm not much of a fiddler with settings so would rather buy into it when everything is more stable.
I've been waiting ages to upgrade, a few months more won't make a difference.
I've had a 3900x on pre-order for a while. I just called OCUK and they said "yeah.... don't expect that anytime soon"...(basically)
So I'm now deciding on 3700x or 3800x.
Haha no, I think the 3900X is overkill for me just now but I keep my systems a long time.Can wait for the 3950X![]()
I've bought the 3700x. To hell with waiting more. I've been waiting since 2015 lol.
Got itI'd get the 3700X personally, I didn't see a substantial enough difference between the two to warrant the extra £50, but either one is probably overkill for current gen games.
Exactly my thinking. Saved £160 and already got PCI 4.0 so I can defo see myself buying again Ryzen 4000.it also means when next years refresh comes I wont mind spending again.
