I'm not sure why he thinks it is AMD's responsibility to make sure that third party tools work with it. Should they alter their CPU behaviour just so that a third party tool doesn't require patching? No.If its this one, i think the AMD rep only mentions hwinfo with dont have multiple monitoring apps open that might contend.
https://www.reddit.com/r/Amd/comments/cbls9g/the_final_word_on_idle_voltages_for_3rd_gen_ryzen/
There is a further response from Martin hwinfo in that thread .
Not trying to be contrary, I dont have Ryzen 3000 so cant try it myself ( currently 2700x ) but am considering it , couldn't live without Hwinfo, see interested to see where this goes ..
I still don't have any confirmation that HWiNFO would be affected by this phenomenon. It is not polling the CPU as aggressively as described, so I don't expect a big issue here.
Honestly speaking, this time AMD has failed big in supporting 3rd party tools. We are still missing several information and advanced support. Some quirks (like detection of sleeping cores) is AMD keeping for themselves, which is a shame. I'm ready to investigate this issue in more detail and take actions if needed. But this requires support from the other side too.
Today I'm planning to release a new Beta build of HWiNFO (v6.09-3855), which should reduce the CPU polling a bit more.
Martin, HWiNFO Author
Might be worth trying the beta if you've Ryzen 3000
Exactly my thinking. Saved £160 and already got PCI 4.0 so I can defo see myself buying again Ryzen 4000.
I think it would be great if AMD made some of their own monitoring techniques open source, thus making it easier for third parties to patch.
Hmm good point, might do the same. Ryzen 4000 might be the last cpu on AM4 so upgrading to it might leave you in better standing if you want to keep your PC for a long time, like me.
I'm upgrading from an i3 3225 (2c-4t) that has kept me going for over 6 years now. I've ordered the 3900x from OCUK, but I'm having to get new parts for every single component, which is proving expensive. Going forward I'd rather spend on a single high-end component once a year instead of purchasing a few high-end and others at low to mid end to save some money.
AMD does![]()
haha exactlyYeah, i loved the bit about forwarding all correspondence with your motherboard manufacturer! Eek!
Yes, went down last night.
Welcome to the club. Mine arrives tomorrow.Just ordered a 3700x![]()
Lets hope that wait isn't too long!Ordered..... !
3900X
MSI X570 MEG ACE
Just got to wait for stock![]()
out of curiosity, why a 3800x over a 3700x?Just ordered a 3800X![]()
