any of the 470 boards getting a refresh, like msi doing ? eta on them any one know? this month ? next month.
got my 3600 cpu today, ram out of stock the now, no board thou, just ain't got the cash the now to go 570 route.
I'll be interesting to see if the MAX boards are identical to the current ones except for the larger flash chip. If they are it won't be that hard to replace the 16MB flash chip with a 32MB one, allowing the old board to use the MAX BIOS.The Max versions of the 450/470 boards that MSI are releasing will have 32MB ROMs, same size as the X570 boards.
I heard from someone who heard that it was 27th july. Some euro stores are listing them to pre order
A few on Reddit reported some shops showing August. As MSI are still clearly trying to stabilise the BIOS (as per a recent thread from an MSI rep on Reddit, where they say there will be a major update at the end of the month) I'd be surprised if we saw the boards this month, but who knows.
TBH I'm getting a little impatient now, so I might just take it on the chin and get an X570. I feel like even with the MAX boards I could still be waiting a while before everything sorts itself out and my 2500k is getting tired.
Thanks for the info. Is this the Reddit post you're referring to?:As MSI are still clearly trying to stabilise the BIOS (as per a recent thread from an MSI rep on Reddit, where they say there will be a major update at the end of the month) I'd be surprised if we saw the boards this month, but who knows.
Thanks,Nice looking build
All up & running with 3700x installed on the Asus Prime X470 PRO, All fine ,
Took the PC 40 odd secs to boot on first power on to set things.
https://www.reddit.com/r/MSI_Gaming/comments/ce3ift/msi_b450_tomahawk_update/
Just got response from other seller, this time from UK, someone should call for overclockers team and ask:
"Hi, Thank you for contacting our support team. These are due in around the 26th however this is not a guaranteed date.
Are you referring to the Tomahawk Max?
If so, yikes! 26th November!
If they are going to take that long to get Tomahawk Max boards out to reatailers, I have to question what the point is, given B550 boards won't be too long after that.
