- 18 May 2010
- London
Nice, what board are you going to run with it?
My current x370 Prime Pro. Should be ok.
None at all, it doesnt touch the GPU. Yes the angled connector came with the case.Very nice. Did you have any clearance issues with that Type C USB 3.2 Gen2 Header? I figure a straight connector won't fit under the gpu, but did you have any touble with that angled connector and was it standard on your case?
No problemThat's great, thanks man.
Here's what the 3900x looked like when i took the stock cooler off, not great contact.
Here it is with some MX-4 applied, maybe slightly on the thicker side but got it as level and even as i could.
Here's two quick shots i took with my phone, will get some better ones with my camera later on in the week when my new lens is here.
3700C and X570 Aorus Elite would be my pick. I got the Taichi cheap but the Elite has essentially the same VRM for far less.
I cant see the video at the moment but Zen 2 does give you a performance boost when you disable SMT. Windows Scheduler is to blame afaik.
Far cry 5
Is this true? I mean in this game turning of smt will give you that much of a fps boost. Can somebody confirm this.
.Keep toying with the idea of these new ryzen chips but I fully well know, I play games that don't need this type of power ( WOW and Classic soon, overwatch apex ).
Ordered a Ryzen 3600, MSI B450m Mortar and an adapter kit for my huge Noctua cooler.
I am still deciding on ram.
This should absolutely destroy my i5 3570k 4.4Ghz setup. Excited.
Holy cow that is cheap. How tight can you get the timings compared to B Die?I'd go with the Crucial Ballistix 3200MHz (BLS8G4D32AESTK) that can be currently had for £29.99 per 8GB stick, Micron E-Die IC's on it so it will do 3600MHz+ if you want to OC it.![]()
How on earth are these so cheap?I'd go with the Crucial Ballistix 3200MHz (BLS8G4D32AESTK) that can be currently had for £29.99 per 8GB stick, Micron E-Die IC's on it so it will do 3600MHz+ if you want to OC it.![]()
Ninja edit: It seems Nghtmare has the same view!
Not as tight, but I've got a pair of 8GB's up to 3733 C16-19-16-16.
They are cheap, because that are made by Micron (they own Crucial) and not a third party vendor who is buying form a manufacturer, then speed binning as creaming people for most profit possible.
That is actually pretty good. Im currently running my 8Pack kit at 3800Mhz 16 16 16 32 1CR 1.4v.Not as tight, but I've got a pair of 8GB's up to 3733 C16-19-16-16.
