Intel are ****** on the desktop.
I love the way they sold more 2200G's than they sold 9900K's
That must sting...
I find the cpu usage of the 3900 in games quite amusing.
5700XT is working it’s nads off pumping out Division 2 on ultra at 1440p and the 3900 is sitting there chilling and tapping its watch at 7%![]()
Ah I missed that, I'll go join now. Thanks.
Edit: Can't seem to find it. Must be blind.
Edit 2: Is it the one in the CPU subsection with Gibbos and 8pack recommendation?
That is a very 90's thing to do ^^^^
Today we have Spotify, everything is on there...
Just a one time thing then I can access it locally from my own hardware. High quality, no internet issues to worry about. Is Spotify like Netflix ie lower quality stream than say a Blu-ray disc?Great thanks. Will post in there.Yeah its all in that thread, I have had no issues with the SB fan run it on silent profile and you don't hear it. I have now seen its adjustable too in the motherboard utility program in windows so might adjust it down more and see how it goes.
Only a tenner and I saved more than that on the RAM I ordered the othe day. Can't complain really. OCUK were cheapest option for the 3 components that I ordered today. Probably will be on the 5700XT when I order that in due course.I'm glad i bought mine when i did.
Sucks for you![]()
3600 CL14 is better but it will take a good die like B-die. Unfortunately, prices of ram just recently went up. So, even 3200 CL14 is expensive since it is B-die. You'll end up with 3000 or 3200 CL16. O'cing it isn't gonna help much cos of loose timing. Popularity of Ryzen must have raised the prices of DDR4.
if you subscribe to the overhyped gouge ram - that is the b-die...Popularity of Ryzen must have raised the prices of DDR4.
none that are 100% guaranteed afaik.which ram on ocuk's sales are micron e-die?
micron e-die is nearly just as good and less than half the cost, and can easily get 3200c14 speeds overclocked
not that ram speeds are a big performance determinant for ryzen 3000 anyway...
no doubting that with all that's going on with the world.it will go up
hah. indeed. the upgrade itch is dying to be scratched lolthen roll in b550 and BOOM- ITX for yourself !
Lol well it's free and in any format I care to ripJust a one time thing then I can access it locally from my own hardware. High quality, no internet issues to worry about. Is Spotify like Netflix ie lower quality stream than say a Blu-ray disc?
Obviously, you're not getting lossless audio from Spotify or probably any other streaming service. That would be a pointless waste of bandwidth.Lol well it's free and in any format I care to ripJust a one time thing then I can access it locally from my own hardware. High quality, no internet issues to worry about. Is Spotify like Netflix ie lower quality stream than say a Blu-ray disc?
Well, my moan about the 3700x and X570 not working is over.
The last chance saloon this morning;
Took the board out of the case, no components fitted, and flashed the bios fine.
Weird how it didnt work in the case.
Then fitted the min components needed to use the bios.
Bios updating screen - finally something working
Then got to bios, closed down inserted all components, and got to windows - eventually, had to get used to the components.
Slowly getting used to being back on AMD.
No quality gaming yet, need to clone my hdd first, and check out further settings![]()
