The above was while benching with 100% load, while gaming Metro Exodus all cores seem to be at around 4300-4350 which is perfect to me (not doing anything that takes 100% of all cores)Stock all core clocks are disappointing.![]()
Not yet, just don't see the point at the moment, it looks like gaming gets maximum anyway. But looking at specific cores 2 of them always get maximum 4.375, so I doubt all core OC would go over 4.35. I think there are always some crappy cores on those cpu that block high OC. 6 of my cores have seen >4.6Have you tried an all core overclock?
Aside from the latest BIOS not allowing my normal keyboard + mouse to work in the BIOS (I had to plug in some other external USB keyboard+mouse and it worked then, for some reason), it seems stable.Im at a loss at which CPU to buy for mine. I dont need the 16 threads of my 2700x, but it kinda feels backwards to "downgrade" to a 3600x by core count, even if it out performs in every way almost? CH6 doing okay with these new chips though?
Anybody tried new bios version 7201 I'll update it tonight. Hopefully they will have fixed the post C5 error.
Yep I've got the same as you. The big problem I have is cold booting. I cannot run my RAM over 2666. I've tried a few fixes like the boot ram voltage but nothing works. To add to the spice I have 4 sticks of RAM. So as long as you run your RAM slow for the moment you will be fine.Is anyone running a 3rd Gen Ryzen with a C6H? I've got a 3900X unopened but I'm yet to install it due to all these bloody issues at the moment with error codes on boot etc.
Thanks for that, hopefully they will get a move on and fix the problems.Believe the only fix is for the mouse issue some people had in the bios. Otherwise 7201 is the same as the last bios.
Yeah, guess the bios intern has a lot on fixing up bioses for 40 odd motherboards.
Interesting thing I've noted: in Cinebench R20 I get 4721 after I close Origin, Steam, GOG Galaxy, Battle.net Launcher. In the default state with these open, I score around 4300.
