- 26 Sep 2017
- In the Masonic Temple
What you wrote probably was fantastic, but you made me cry with laughter with the typo and things you typed lmaoWell built my 3800X setup on an ASRock x570 Phantom gaming 4 with some T-Force dark pro 3600 RAM. I swear I bought the Thermaltake Water 3.0 and it said it had AM4 bracket, but as NZXT stuff like the G12 Kraken supports other manufacturers AIO pumps I managed to use the Kraken X62 brackets with the thermaltake AIO as I couldnt be bothered to dismantle the Kraken on the 1080ti.
It's been so long since I reinstalled windows from afresh that I forgot how long it took. I ache between the legs. So too with a BIOS especially with so many more variables and options. Just left it all on auto and adjusted the RAM to 3733Mhz and so far runs well. Seems in all the monitoring software including AMD's own in Ryzen master the CPU temp graphs are sawtoothed. Gaming PUBG @4k saw max temps between 50 and 65 degrees. Idle around 50 degrees but I havent adjusted the apparent high voltage even at idle people are experiencing. The minumums in framerates are much higher and the fps counter meaning less variance on the framecunter. So much smoother experience. Thgough the game has just had a significant patch so dunno how much is down to that. I'll try FARCRY 5 later.
What I did notice from the Afterburner graphs on the core usage is that across the 8 cores they varied from 80% use on the highest core and down to single figures on the lowest core. The cores all bosted to same speed (I have PBO on currently) and the core sped was 4350-4450 during gaming.
CPU-Z saw 544 in single thread bench test.
Now just wait for the BIOS's etc to develop to maybe increase performance or fully working according to those who realy know what they are on about, though could be just older boards.
