Use this software help a lot for clocking Ram on Ryzen chips.
https://www.guru3d.com/files-details/download-ryzen-dram-calculator.html
Just out of curiosity, the calc shows you a chip quality % on the second tab, where is everyone at? Mine shows 92%
Here a better result 1.45v been tweaking sub timing.
The one that was pulled AFAIK is 1.0.0.3ABA, but now they are working on version ABB according to AMD.Looking across the line up of ASUS x370 boards they do seem to be lagging with upgrading to he latest AGESA.
I did come across a post saying that it had been pulled due to some bugs. But not sure if that was getting their wires crossed as it was the last AGESA that was pulled not the latest one. But the post was only 2 days old.
No, AB is the "official" AGESA for Zen 2. ABA is the buggy versionThe x470 boards did receive a new BIOS tho: AGESA 1.0.0.3 Patch AB
Is that the old one that was buggy that they eventually released?
So this was only a week ago so I guess I can forgive ASUS.
@opethdisciple in general i dont give a **** what amd says i run tests and check if its stable. I got Stable system You got hiccups reboots ect.
If You want to stick to what AMD says. STOP OVERCLOCKING simple as that.
but You'r not running 3800/1900 are You ??But it's working now tho.
Have You tried 101.8 bclk ?? Cause You are running basically Stock settings now Where is fun in that??Nope. Only cause my IF cant go higher than 1800MHz. The ram can go as high as 3800MHz, but the IF cant go above 1800MHz. No amount of volts changes that situation.
Does cut around 0.2ns more or less from what i get on blck 100.@Zeed
62.5ns nice! Thank you for sharing
So looking at your C16 timings is the 101.8 bclk helping with latency score? My tighter C15 timings typicaly score around 63.8ns, or does the 3900X score better than the 3700X due to cache differences?
