:/Price rise on 3700x. Was just about to buy lol
What have you deiced on?
Have You tried 101.8 bclk ?? Cause You are running basically Stock settings now Where is fun in that??
Still cheaper elsewhere.Price rise on 3700x. Was just about to buy lol
That!:/
As you're only using 2 sticks your memory won't be an issue regardless with stock cooler.Will my ram fit under stock cooler?
It's been A THING since Zen1 came out. Iw been running BCLK oc since alpha state bioses on zen1..... Tahts how i got first High memory low latency stable around most forums. When people had problem to even boot above 3000mhz lol.Haven't tried that nope. Didn't know it was a 'thing'.
Does cut around 0.2ns more or less from what i get on blck 100.
https://hdqwalls.com/wallpaper/7680x4320/amd-ryzen-8kWhere can I find that wallpaper dude?
same 93%93% Quality for me.
No, just that they are not rushing out BIOSes due to past experience with issues when doing that, they want to take a little more time and get it right.
I can respect that.
Just out of curiosity, the calc shows you a chip quality % on the second tab, where is everyone at? Mine shows 92%
Mine shows 92% after importing the HTML file, I don't even think I checked before thatBefore or after importing SPD from Thaiphoon?
If before it's always shown 93%.
If i import my SPD into the calculator it then shows 81%
Ive had the one that improves Destiny 2 compatibility for a few days now on X570 Taichi (30/07)Which mobo vendor seems to be providing the best BIOS ongoing support?
Seems Gigabyte are the quickest of the blocks with getting thier full stack upgraded to the latest AGESA from x370 - x570.
good point cause the V1 timings are tuned for 93% quality Bdie gskill kits.Before or after importing SPD from Thaiphoon?
