AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Got mine Saturday for £280 used up my promotional credit, noticed price gone up on these now
Need a board though. Been looking at a few. Wonder if the chipset fan being a bit further down makes any difference to temperature on the Aorus Elite? The Asus pacman board looks decent as well.. dunno, ram i ordered shouldn't be an issue for either board, G.Skill said need to wait for BIOS update for the Gigabyte board to support the 3600mhz neo kit.
I think maybe just get the Asus.
2 Jan 2019
Talking of chipset fans...when I power up my X570 Gaming Edge WIFI, sans CPU, the fan kicks in 100%. Wasn't expecting that TBH. Makes a bunch of whooshing air noise whilst outside of case. Seemed louder than all of my case fans running at 100% and the cooler fans at 100%.
21 Jun 2018
Ashton
Try to set a fan curve for it or change the preset in the BIOS (if you have the option). My Asrock board had it on 100% by default but I set it to Silent.
At lest I change settings in bios and it changes settings and boots up. People constantly say but its asus tax ye tax for stuff to actually work :p Maybe we only had 3 bioses for C7H so far but at lest One is working great :)
I previously had a Strix Z270E and it worked really well, the BIOS was easy to use and it just worked. First time using Asrock and so far so good.
19 Apr 2012
I must have just been unlucky with Asus stuff in the past. Only ever had issues with them and the resulting customer support was always terrible which is why I tend to avoid if I can.
