that's a rank image to have in my head at 10 in the morning - thanks for that!Not for long as the new plastic ones will cause more smearing than wiping.
you on commission at OcUKYou let it happen in your mind mate, all in your mind. Easy way to aleviate; buy that 3700X and have that fluffy feeling all day that some new shiny is turning up tomorrow. EXCITED!
and sadly as a resident of the far flung corner of the UK that is Northern Ireland next day delivery from OcUK is but a dream
From x570 lineup I would not go below thats 4+2 phase. You could always get C7H like mine thats 10+2 barely sweating here with over 200w power draw by cpu abuse so far 14 months nothing died and its running 24/7@Zeed
Which Asus motherboard would you recommend without going to mad on cost?
Something that would easily support a 12-16 core in the future.
lol thanks I will wait until can get some alcohol what kind of cloth do your recommend?
Wouldn't your wife/partner/girlfriend's make-up remover wipes suffice? It would save having to buy a stack of wipes out of which your only going to use 1 or 2 at most.Just buy a box of the Noctua cleaning wipes:
https://www.overclockers.co.uk/noctua-na-scw1-thermal-paste-cleaning-wipes-20-pieces-th-003-nc.html
I just nick a pack of baby wipes from my missusWouldn't your wife/partner/girlfriend's make-up remover wipes suffice? It would save having to buy a stack of wipes out of which your only going to use 1 or 2 at most.
https://www.techpowerup.com/review/asus-prime-x570-pro/4.html
My new shiny 3600X arrives today.You let it happen in your mind mate, all in your mind. Easy way to aleviate; buy that 3700X and have that fluffy feeling all day that some new shiny is turning up tomorrow. EXCITED!
One thing that is bothering me now is my VDDG voltage. I found some official AMD Ryzen master documentation that clearly specified that VDDG should be started at 1.1v for memory overclocking.
With SOC at 1.1v and VDDG on auto with current speed I was getting intermittent freezes. With SOC and VDDG at 1.1v my problems have disappeared and all is well.
Whats the issue you say?
Well previous BIOS didn't care about 1.1v on the VDDG voltage. Latest BIOS turns red when I set 1.1v on the VDDG.
Not sure if ASUS are trying to tell me that on this mobo 1.1v on the VDDG is considered high or it's completely fine and I am worrying about nothing.
Hopefully it actually works lol.
Thanks.Hope all goes well for you this time
I gotta be honest. ONE AND ONLY reason I went back to Asus for Ryzen when it came out was... USB ports on I/O Shield. I would have went ASRock Taichi x370 instead. As an oculus rift user i utilise:Thanks Zeed, I shall go have a look into that board.
It's because VDDG Should/NEEDS to be at least 40mv Below SoC voltage. Soc under load drops to below 1.1 and VDDG wants to pull 1.1 and thats why its ******.One thing that is bothering me now is my VDDG voltage. I found some official AMD Ryzen master documentation that clearly specified that VDDG should be started at 1.1v for memory overclocking.
I just nick a pack of baby wipes from my missus![]()
From The Stilt:
Matisse introduced a new voltage adjusment, called cLDO_VDDG. VDDG is the fabric voltage.
At default it is 0.950V however, some motherboards might increase above the default level even at stock settings.
cLDO means the voltage uses a drop-out (LDO = low drop-out) regulator.
Most cLDO voltages are regulated from the two main power rails of the CPU. In case of cLDO_VDDG and cLDO_VDDP, they are regulated from the VDDCR_SoC plane.
Because of this, there are couple rules. For example, if you set the VDDG to 1.100V, while your actual SoC voltage under load is 1.05V the VDDG will stay roughly at 1.01V max.
Likewise if you have VDDG set to 1.100V and start increasing the SoC voltage, your VDDG will raise as well. I don't have the exact figure, but you can assume that the minimum drop-out voltage (Vin-Vout) is around 40mV.
Meaning you ACTUAL SoC voltage has to be at least by this much higher, than the requested VDDG for it to take effect as it is requested.
Adjusting the SoC voltage alone, unlike on previous gen. parts doesn't do much if anything at all.
The default value is fixed 1.100V and AMD recommends keeping it at that level. Increasing the VDDG helps with the fabric overclocking in certain scenarios, but not always.
1800MHz FCLK should be doable at the default 0.9500V value and for pushing the limits it might be beneficial to increase it to =< 1.05V (1.100 - 1.125V SoC, depending on the load-line).
https://www.overclock.net/forum/10-...echnical-matisse-not-really.html#post28031966
3 usb ports for VR sensors fixed to my full scale vr gaming whatever living room.
1 for bluetooth adaptor for xbone pad and oculus touch controllers and oculus remote
1 usb to power VR helmet itself
1 mouse
1 keyboard
1 usb cable to charge my phone
1 to powetr my Saiyan RGB LAMP
So atm I got 8 devices plunged in and sadly Most moptherboards dont even have 6 on IO shield. And those VR sensors dont work well with usb hubs and best if they are on separate usb controllers. So got 1 in cpu usb3 1 in cpu sub2 with powered usb extention cable and 3rd in chipset usb3.
Thing is Crosshair VII is like 250 quid atm thats allot of motherboard when You look at x570 prices. But You wont get PCIE 4.0 cause AMD killed it off :/
