- 18 May 2010
- London
I missed that cause was listening ye.
He pressed the R-XMP button which reads the timings.
It only loads preset V1 timings not actual Dram kit timings... Thats why I said You not used calculator how it should be used 99% chance lolHe pressed the R-XMP button which reads the timings.
Technically he's not done that correctly though has he?. He hasn't imported his kits SPD into DRAM calculator first to see his current memory IC quality.
I have B-Die memory but it won't work on V1 timings as that assumes a 93% IC quality, where as mine is only 81%
calculator shows it when u load spd dataHow do you find your IC quality percentage? Thanks.
Yup thanks guys, will check out Auros elite too. Thought they generally weren't recommended.
I've got a 3800X on a Aorus Elite and I'm well happy with it. Let me know if you want to know anything.
Load up Taiphoon
>Click Read (at top)
>Click Read SPD (on any of the list that shows up)
>Click Report (at top)
>Scroll to bottom of report
>Click "show delays in nanoseconds"
>Click Export (at top)
>Click Complete HTML Report
>Save the file
Open DRAM Calculator
>Click Import XMP and choose the file you just saved
> In drop down lists choose the Processor version you want (i.e. Ryzen 2 gen for the 3000 series CPU's), Memory Type you have (i.e. B-die), Memory Rank, Frequency you are wanting to achieve and the amount of DIMMS, and which motherboard chipset you are using.
>Choose either safe or fast preset
>Click Advanced tab and near the bottom left it will tell you your IC quality and what it thinks is the best Frequency you will get
I recently created a new thread actually as I didn't want to clog up this one speaking about motherboards. How are you finding it generally? Good BIOS updates and easy enough to use? Have you had the issues with boot times being slow?
It's a good stable board with all of the features I need and more. I've come from an Intel platform and haven't find anything difficult to use. Just need a bit of Google-fu if you want to do any in-depth tweaking.
The VRMs are good especially for one of the less expensive boards.
The chipset fan is unnoticable to me and positioned well - doesn't get covered by the primary GPU like on some boards.
There's been two BIOS updates since I got it and both have brought improvements. The only BIOS I had a problem with though was the one that it shipped with (F3).
The only time the boot time is slow is when I change something in the overclocking/tweaking section of the BIOS. When that happens, the board goes into an extended boot-up when it does memory training and probably stuff that I don't understand. If the changes are valid and supportable then it boots fine and the changes are saved then all subsequent boots are not slow. If the changes fail the tests then the BIOS gets reset.
My 3800X performs and boosts as advertised without any messing about with voltage offsets or anything.
I think the only thing that is wrong is that the case fans seem to run at full speed when the PC is woken from sleep. A reboot sees the fans return to following the fan curve set in the BIOS. This is a bug that's registered with Gigabyte and I fully expect it to be resolved in a BIOS release soon.
After importing your timings from the dram calculator you should use the manual profile then or stick with profile 1?
Load up Taiphoon
>Click Read (at top)
>Save the file
I just get a blue screen when windows boots using the dram cal timings. I suspect it's the mobo now which is the limiting factor.
But If Steve from hardware unboxed is right, I learnt that you leave all the volts on auto but just put the dram voltage. So back I go to CL16 3600MHz and try upping the dram voltage and see if I can get that to be stable.
Could you give me step by step instructions please? Kidding obviously
Great post thanks.
