Tamzzy's back to air-cooling ITX build
Man of Honour
OP
26 May 2012
Can i ask, why did you buy that case?
i've always preferred smaller builds (hence all my computers have been matx/itx builds) and i did like the rvz01. the rvz03 is less garish in comparison, so the natural choice when comparing both together
yes i know you can get smaller cases than the rvz03 - like the dancase, ncase, sliger etc - but those are like 150-200+ quid and i didn't want to spend silly money. (and even if i did, i still wouldn't have bought those cases as i'd have spent the extra and got the 3900x instead...lol)
Man of Honour
OP
26 May 2012
I am looking at building a complete ITX system or buying the Asrock A300
well i think you're looking at 2 totally different spectrums of the SFF market lol. the Asrock A300 is a "proper SFF", where as the RVZ03 (although still small) can be considered more as a powerhouse small build.
i think you need to decide first what you want, and then see what your budget is.
19 Apr 2003
@Plec even with insufficient tim, it's still maintaining it's boost clocks. albeit at 95c lol :p
Poor, underappreciated CPU, with 7 year old pea sized blob of MX2 and then subjected to synthetic stress tests. (8g of MX4!!!) :D
What are the PCH temps/fan RPM. Assuming it's probably the one area that may have to work that little bit harder considering limited airflow.
Man of Honour
OP
26 May 2012
it's less than pea sized. probably more like half a grain of rice ;) i wasn't kidding when i said i wasn't going to waste tim on what is, essentially a test run lol
PCH temps
54c at gaming loads - its getting cooled by both the tweeny chipset fan and also the gentle typhoon via the cpu cooler
CPU fan = 1790 rpm (always max speed)
2x 120mm slim fans on the GPU intake side = 800rpm (again, always max speed)
1080ti = 75c @ 60% PWM roughly 2200rpm at gaming loads
2 Dec 2004
Under The Desk, Wales
Got these 2 comparisons:
AMD Ryzen 5 2400G VEGA Graphics AM4 CPU w/ Wraith Stealth Cooler
AMD B450 I AORUS PRO ac WIFI Mini ITX AM4 Motherboard
Corsair 16GB Vengeance LPX DDR4 2400MHz RAM/Memory Kit 2x 8GB
Intel 660p 512GB M.2 PCIe QLC 3D Performance NVMe SSD/Solid State Drive
EVGA GM 550 Watt 80+ Gold SFX PSU/Power Supply fully modular
(Already own an ITX Metis case)
£427
Asrock A300 case
Corsair Vengeance 16GB DDR4 SODIMM 2400MHz Laptop Memory 2x8GB
ASRock USB 2.0 Header to 2 x USB 2.0 Cable for DeskMini Series Chassis
ASRock Wifi Kit for The Deskmini Mini-Stx Chassis X Antennas
£425
19 Apr 2003
>discrete GPU not required <
If this is for office work/very light, non-demanding gaming then the above are solid choices and depending on where it's going i would choose aesthetic/form factor over potential upgrade path (would choose a different M.2. drive).
That said - i personally would prefer build number one as it would give me the the foundation to uproot and move to a more substantial build if my needs/games tastes changed in the future.
EDIT: Do you own the memory already for build number 1?
19 Apr 2003
LOL - if you apply this logic to your first dates (test run) you must make quite the impression. Fridge left-overs and a drink if she/he/none binary is lucky and then still holding out for fourth base near the end of the date :D
If i do start looking seriously at the FTZ10B for a living room PC - i may ask you to briefly experiment with a curve to see how it performs.
No need to now -as:
  1. i'm pretty sure your CPU would spit its dummy out at the test curve i would want to try with only a fraction of the CPU covered :p.
  2. it may be a pipe dream; but this Xbox one X i got for the kids isn't being used - so may sell it/both - as i know a PC would get some use. Tried Steam Link - but too hit and miss but great for Jackbox.
  3. you will have better things to do with your new toy.
2 Dec 2004
No i dont. I would have to buy everything except the case.
Man of Honour
OP
26 May 2012
instantly eliminates the gold diggers :)
it's surprisingly quieter than my old rig. granted that having 4 gentle typhoons may have skewed the comparison somewhat...
19 Apr 2003
@Plec @tamzzy ain't paying for the case so many ght as well go nuts with little time I have :D
Great - get that dremel charged.
You need to sub the memory out for 3000MHz/3200MHz memory (Crucial Ballistix Sport LT (AES) - set tighter timings even if you can't clock) to get the optimum performance out of Ryzen (Price difference is nominal)
2 Dec 2004
Depending if i wanted to game massively i guess. I will be gaming but obviously at low settings.
I guess first option gives me the chance at a later date to get a dedicated gpu if i so wished
19 Apr 2003
The Crucial is E-Die memory - and is approx ~80. It's premium performance for minimal outlay - and would compliment Zen-2 (and clock) were you to upgrade in the future.
For example - @tamzzy has clocked his 3200MHz sticks to 3733MHz C16 with minimum effort - on a Zen-2 build.
2 Dec 2004
Right, i see. Any link to that memory just in case i look at the wrong one. Ta
19 Apr 2003
I can't give you a link but as OcUK don't sell it i can give you name and product code - but know it can be bought for £80 when looking:
Crucial Ballistix Sport LT BLS2K8G4D32AESBK
