- 10 May 2004
- Middlesex
Finally nice to start seeing some strength gains after months or stalling/regression. I'm pretty much working back to where I was but it's getting there quickly!
Finally a decent week. Still 86kg (doubt it’ll stay there for long), but hit 80kg OHP two weeks in a row feeling really good and deadlifted 4 sets of 5 at 200kg. Will hopefully start pushing all my max lifts before too long. No niggles, no pains, everything felt solid.
Great week for me as well. BW finally dropped below 100kg so I'm no longer obese, I squatted 135x10 and benched 95x10 on Wednesday and deadlifted 155x10 last night.
Finally feel like I've got a good foundation to build from now.
To add to this, managed 120kg bench for 4 sets of 5 with zero shoulder pain this morning. They were all pretty smooth too. Will be interesting to see what my 90 and 95% lifts are like next week.
Going back to Monday/Tuesday squats this week. Will be interesting to see if I can get a squat rack at 6pm.
Can anyone give me advise or personal experience from swapping from standard 5x5 progaram to Madcow5x5?
I am considering doing this now, but unsure if its worth it or what to expect in terms of outcome.
My starting numbers for 5x5 and current numbers below:
Starting:
Squat: 50KG
Bench: 40Kg
OHP: 40.0KG
BBRow: 40KG
Deadlift: 40KG
Current:
Squat: 125KG
Bench: 82.5Kg
OHP: 55.0KG
BBRow: 80KG
Deadlift: 130KG
I am mainly just trying to continue to get a bit stronger, cut some body weight and generally just get in better shape.
I am wondering if its worth changing to the Madcow, or dropping the weight a bit and upping reps to either 3/5 x 8/12?
What do you all think?
Whilst you're getting stronger, are you losing fat? Are you happy with the results you're getting? Change if youo want to, but in all likelihood you won't notice significant additional progress without working out if you want gains or aesthetics...
I guess my biggest issue is that i want a little of both? Which is probably not realistic.
I wanted to get stronger but also see some visible results too.
As for losing fat, I cant really tell in terms of numbers, which is why I should probably get it measured (even roughly) and then see if i can have a positive impact on the results.
I'm certainly more muscular in areas where I have never been before, and have replaced fat with muscle for sure! But there is still some chub (typical dad type areas), which is now what I want to try and shift.
But at the same time i don't really want to give up any strength and size I have gained in the last few months.
I guess I cant have it all.
Well, it depends entirely on your training history, too - if you're new to lifting, then you can probably still make *some* gains/progress whilst your neuromuscular system tops out, all while shedding fat.
As to measurements of fat: kind of academic because the difference between X% and Y% is meaningless unless there is a visible difference... and if there's a visible difference, the measurement is also meaningless.
Based on the above, unless you have the physique of a "middle-aged office worker," I would just keep going and add a set of kettlebell swings to failure in at the end of every session. Losing weight whilst lifting takes all the fun out of things unless you have something specific in mind...
At the moment, I'm keeping my weight constant despite bucketloads of cycling and a bit of lifting because whilst I'm still slowly trimming fat I'm keeping my muscles ticking over with some "not particularly interesting" lifting. I used to be a lot stronger than I am now but my current focus is about getting as fast as I can on my bike: eating everything, training hard for strength/size doesn't leave much room for bike efforts, so I just accept I'm not going to be as big/strong as I (used to think I) was...
Yeah that makes total sense.
Most certainly not "out of shape" at least for my age and my job. So I know I dont have anything to worry about there.
Maybe ill stick with the 5x5 until the end of Autumn, see where I can get to with that before looking to change things up a little.
Starting:
Squat: 50KG
Bench: 40Kg
OHP: 40.0KG
BBRow: 40KG
Deadlift: 40KG
Current:
Squat: 125KG
Bench: 82.5Kg
OHP: 55.0KG
BBRow: 80KG
Deadlift: 130KG
Just to add what others have said, if your current weights are your max or your working sets, you do not and should not drop as low as 40kg on every exercise, especially not deadlift, that should start at a min 60kg so as the bar is correctly positioned off the floor.
Also think of the lifts in % terms, your squat you want to roll back to 40% of your current, but your OHP to 72%...your deadlift to 30%....at most you would want to start a new program out with week 1 day 1 lifts around 65-70% current maxes. If you want to be conservative then go for 65-70% of 90% of your current max.
Generalised mobility, really, as well as yoga. It's difficult to recommend without seeing photos and videos (), but a good trainer/physio will be able to go in for specifics. In general... start with stretching your back (foam rollers), lats (rollers, tennis balls, resistance bands) and pecs (golf balls -
). Then consider bucketloads of lightweight resistance work focussing on your scapular/shoulder positioning: practicing perfection is the best way to perfection... sample exercises:
The important thing is to focus on what your back is doing and ensuring yoru positioning is immaculate: this may take some time to get right because it sounds like your brain has it pegged in the wrong place. This is where a physio comes in useful (second pair of eyes!), but you can *kind of* replicate it by standing in front of a mirror or proprioception work (ask Google/Youtube) with a laser pointer...
- single arm rows and presses
- lateral raises
- lat pull-downs (uni/bi-lateral provided your positioning is good)
- deadlifts
- front squats
- reverse delt flies
