AMD FidelityFX And Radeon Image Sharpening Tested vs DLSS
OP
25 Nov 2011
The KOP
Radeon Software Adrenalin 2019 Edition 19.9.2 Highlights
Support For
  • Borderlands 3
    • Up to 16 % FPS improvement on the Radeon™ RX 5700 graphics card running Radeon™ Software Adrenalin 2019 Edition version 19.9.2 vs. 19.9.1 drivers.RS-312
  • Radeon Image Sharpening
    • Now available on Radeon RX 590, Radeon RX 580, Radeon RX 570, Radeon RX 480 and Radeon RX 470 series desktop graphics products for DirectX®12 and Vulkan® applications.
28 May 2007
Support For
  • Borderlands 3
So available on the 5 and 4 series but not Vega. Surely if they can use it then so can Vega.
OP
25 Nov 2011
The KOP
They're out.
Radeon Software Adrenalin 2019 Edition 19.9.3 Highlights
Support For
  • Tom Clancy’s Ghost Recon® Breakpoint
    • Now available on Radeon VII, Radeon RX Vega 64, Radeon RX Vega 56 and Radeon Vega Frontier Edition graphics products for DirectX®12 and Vulkan® applications.
Fixed Issues
  • Sekiro: Shadows Die Twice™ may exhibit texture corruption during later parts of the game.
  • Discord™ may experience an application hang on Radeon RX 5700 series graphics products when HW acceleration is enabled.
Known Issues
  • Toggling HDR may cause system instability during gaming when Radeon ReLive is enabled.
  • Display artifacts may be experienced on some 75hz display configurations on Radeon RX 5700 series graphics system configurations.
  • Call of Duty®: Black Ops 4 may experience stutter on some system configurations.
  • Open Broadcasting Software™ may experience frame drops or stutter when using AMF encoding on some system configurations.
  • HDMI® overscan and underscan options may be missing from Radeon Settings on AMD Radeon VII system configurations when the primary display is set to 60hz.
  • Stutter may be experienced when Radeon FreeSync is enabled on 240hz refresh displays with Radeon RX 5700 series graphics products.
  • AMD Radeon VII may experience elevated memory clocks at idle or on desktop.
Important Notes
  • AMD Ryzen™ Mobile Processors with Radeon™ Vega Graphics FAQ for Radeon Software Adrenalin 2019 Edition can be found here.
Package Contents
The Radeon Software Adrenalin 2019 Edition 19.9.3 installation package contains the following:
  • Radeon Software Adrenalin 2019 Edition 19.9.3 Driver Version 19.30.25.01 (Windows Driver Store Version 26.20.13025.1004)
The Radeon Software Adrenalin 2019 Edition 19.9.3 installation package can be downloaded from the following links:
By clicking the Download button, you are confirming that you have read and agreed to be bound by the terms and conditions of the End User License Agreement (“EULA”). If you do not agree to the terms and conditions of these licenses, you do not have a license to any of the AMD software provided by this download.
6 Feb 2019
It is finished...wish they did it for older cards as well though :(
yeah dunno why it's such a big issue - it's a software solution and already working on nvidia cards too - nothing tricky about it as far as I'm aware - it could be enabled on probably any graphics card old and new. it's not ray tracing or dlss that requires specific hardware etc.
OP
25 Nov 2011
The KOP
Sure it's not a hardware-based tech like DLSS etc but it does require more than you let on. It does work on the fly to add sharpening to the image, it doe not sharpen the whole image like reshade does!
17 Oct 2009
Agreed, it'll hit AMD hard unfortunately for them. Assuming there isn't a quality difference or any other issues, though HU seemed convinced. I wonder if they'll bring it to the cheaper end of their product stack.
